Will lowering my car hurt my track performance?
PR Director
I have heard that lowering your car hurts you at the track, but its good for the streets, turns and what not. Is this true? I just ordered some springs and would to know this before I have them installed! Thanks for your input.
Mike-Z
Mike-Z
I've heard of it helping for road racing, but not drag racing.If anything, lowering your car will hurt drag racing performance, because of weight transfer, I believe. <img src="images/icons/smile.gif" border="0">
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
A response to one of my posts someone noted that lowering your car will ONLY effect traction if you dont get relocation brackets. I dont know if the brackets will also cure the weight transfer problem. Can someone else clarify?
I have had my car lowered a little over a year now. I can't tell any difference at the dragstrip, it seems my car spins a little more since I got it lowered but it may be my imagination and the tires are a little slicker <img src="images/icons/grin.gif" border="0">
[ December 10, 2001: Message edited by: ZLEEPER01 ]</p>
PR Director
I have lower control arms coming also, and I still need to order relocation brackets. Will these help traction and weight transfer, if I am getting an Adjustable PanHard Rod to?
Thanks guys
Mike-Z
Thanks guys
Mike-Z
The new LCAs and brackets will help. I have Eibach sportlines on my car - really low - and upgraded the rear suspension w/ adjustable BMR stuff (LCA, Panhard, TA) and LCA lower brackets at the same time. My 60' times remained pretty constant before and after, and wa pulling mid-1.8 short times on street tires (F1s) late in the fall. So you can have your cke and eat it too with the right mix of parts.
I have Hodgkis 1.5" lowering springs on my car. But no relocation brackets Which I just ordered. I strongly recommend getting the relocation brackets. Unless I pull the front sway bar I get zero traction. And for street driving no front sway bar feels like A$$. Just my .02, Jason
[ December 10, 2001: Message edited by: SC 98 Mecham ]</p>
