To Gridle or not to Girdle
Old May 4, 2005 | 02:32 PM
tirefryer's Avatar
Default To Gridle or not to Girdle
What are the opinions out there about putting on a rear end girdle with a stud kit. Is it worth the money? Would just putting some good fluid be enough? I have an M6 and I know they are prone to exploding at the track, and I want the 10 bolt to last a while.
Old May 4, 2005 | 02:45 PM
1 BLOWN V8's Avatar
I would also like to know this. I have a A4 with a stall and 342 gears. I have been kicking around about adding one also. Lets hear some input
Old May 4, 2005 | 03:05 PM
Turo's Avatar
If you are trying to keep the 10 bolt as long as possible, then yes the girdle is a good mod, should add some structural integrity. Personally, I don't have one just because I am trying not to spend any $$$ on the stock rear, since I would like to swap it out soon for something stronger as soon as I've saved enough cash.
Old May 4, 2005 | 05:39 PM
Chas1's Avatar
I asked the same question last week, not much response. I went ahead and ordered one, I'm having a 3.73 installed and decided might as well make it as safe as possible.
Old May 5, 2005 | 12:34 AM
rotwiler's Avatar
I had my gears done at Randys Ring and pinion, supposed to be one of the nations top gear suppliers and rebuilders. They told me it doesn't help at all. I was going to buy one from them and decided not to after they told me that. It has to do something, I would think and if not at least it is easy to change the fluid.
Old May 5, 2005 | 01:49 AM
98Grnz28's Avatar
Yes, T/A gridle helps . Why does it help is because it keep the gears,locker, and axles for from flexing. So yes it helps.
Old May 8, 2005 | 09:47 PM
blue01ta's Avatar
If you check the parts for sale section theres 1 or 2 for sale right now. If you buy a nice used one for cheap then decideto go a different route then you could probably resell it for about what you got into it.
Old May 11, 2005 | 09:51 AM
2001stripper's Avatar
Could we get a few more responses? I too am very interested in this subject. A guy at the track last night swears by them, although he hadn't yet put one on his car.
Old May 11, 2005 | 10:15 AM
HBHRacing's Avatar
I look at it this way.
you could spend well over a grand getting a new nice and strong posi, axles, c clip emilms, gear set, bigger pinion flange, girdle, rebiuld kit, labor etc etc etc and still shatter the rear with one good pass.
or you can take that about $1,500 and put it twords a 12 bolt. Thats the route that I took.
No matter what you do to the 7.65" 10 bolt you run into one problem. It's still a 7.65" 10 bolt. No matter what you put on around it you still have the main weekness of the gear set.
Old May 11, 2005 | 11:40 AM
I thought 12-bolts typically run between $2000-$2500, but maybe that includes installation. Strange and Moser are the most often talked about 12-bolts....what about the Chevy 12-bolt?
Old May 11, 2005 | 12:03 PM
Brandon Boomhauer's Avatar
they are 'chevy 12bolts' but moser/strange/etc make housings and parts, instead of using old gm rears and stuffing them with parts.
Old May 12, 2005 | 02:21 PM
john shea's Avatar
The girdle is a nice looking piece and makes gear oil
change easier even if it doesn't add strength.
Old May 12, 2005 | 03:04 PM
HBHRacing's Avatar
Like i said. you can take the $1500 and put it TWORDS a 12 bolt. Not buy a 12 bolt with it. It makes a large chunk of the payment. all you need is about another 600ish depending on what you get and if you have it installed. By my logic after you put $1500 making the 10 bolt as strong as you can and pay another 300 bucks after you shatter the ring gear anyway it pretty much pays for itself.
Old May 12, 2005 | 05:51 PM
~JOSHUA's Avatar
HBH makes a strong point.
I got my whole 10 bolt housing for $430 shipped with gears loaded after a figure what I made selling my stock center.
That's a deal I couldn't pass up since I spun carrier bearing in the old one anyway. NOW I will start saving for the 12......
Old May 12, 2005 | 07:46 PM
jdustu's Avatar
yes, the girdles are worth it....and like a previous poster said, if you end up going with a 12 bolt or nine inch you can sell the girdle. the rest of the parts for a rear aren't gonna hold much value, but a girdle will.......i've got one on my car and it's held up fine so far(a4 ssf4200 drs)......
