install kit for gears, which one?Basic or complete
Old May 12, 2005 | 08:39 AM
2002anniversary's Avatar
Default install kit for gears, which one?Basic or complete
like te top says. does the basic kit cover what ypou need to install or do i need to go to the complete kit or super complete kit. i beleive basic is 50, complete if 99 and super complete is 120. let me know, thanks
Old May 12, 2005 | 09:37 AM
HBHRacing's Avatar
it depends on what you need to do. and what your replacing.
Old May 12, 2005 | 05:09 PM
i am going from a 3.23 to a 3.73 gear. thats all i know.
Old May 12, 2005 | 05:11 PM
HBHRacing's Avatar
Right, but what all is being changed? bearings, Posi, seals, races etc etc etc? if ALL your doing is a gear swap then all you need is the basid kit that has the shims etc etc. If your rebuilding everything get the complete kits
Old May 12, 2005 | 05:43 PM
thats what i was looking for. thank you
~JOSHUA's Avatar
Are you planning to install it yourself? I'd take the whole car to a shop to have them do the job for you. The diff' isn't something you want to touch unless you've had real training and have the proper tools and guages or else...
Old May 13, 2005 | 01:29 AM
LT1-Z28's Avatar
Doing it yourself can be a real nightmare... but if you are not messing around with the bearing races, and have a micrometer and a dial gauge, it prolly wouldnt be too terrible...
Old May 13, 2005 | 10:12 AM
HBHRacing's Avatar
I have done a few (the right way). No it's not fun and yes you risk failure if you don't get it exact. backlash is easy, pinion depth and preload is not. I spent about 500 bucks on specialy tools to do it and I still needed more. I would recomend a shop, but if your brave try it
Old May 13, 2005 | 08:24 PM
hell no . i will leave it up to the professionals
Old May 14, 2005 | 12:06 AM
blue01ta's Avatar
I talked to a tech up here that has set up a lot of these rear ends and he said the same thing unless your car has a lot of miles on it then mybe you should get the bearings. Mine has 40k and he said there was plenty of life in the bearings still yet.
