3.23 -> 3.42 question
I have an 2002 a4 ss w/ 3.23 gears and I'd like to go to 3.42s. I called my local diff shop, they said 3.23 was as deep as I could going with a wide gear.
Reconciling that with a post I've seen here (https://ls1tech.com/forums/gears-axles/335608-2-73-3-42-swap-help.html), I assume this means I have a series-2 diff.
Do I for sure have a series-2, or is it possible I have a series-3?
I am just trying to figure out ahead of time what parts I need to swap from 3.23's to 3.42s, so any shortcuts to that answer would be surely appreciated.
Thanks,
Steve
3.23 and more = 3 serise.
Either way you can get gears to fit any serise. Hell you can get a set of 4.56's for a serise 2 if you want.
Get some 3.73's and don't listen to anything that shop has to say, ever
Reconciling that with a post I've seen here (https://ls1tech.com/forums/showthread.php?t=335608), I assume this means I have a series-2 diff.
Thanks,
Steve
The only gain you'll get is from weight savings as your wallet will be much lighter!
3.73s will help, but buy a converter and keep the 3.23s
Perhaps you are saying it's just not worthwhile; Maybe it's not worthwhile to you, but I have higher streetability standards than you (as evidenced by your 4200 stall converter).
It's more fair to say it's not worthwhile for the money, but the thing you have to keep in mind is for a lot of people on here your f-body is your hotrod, and you're doing everything you can to make it as fast as possible, and you're willing to make compromises.
I have 2 hotrods (both run 9's), my f-body is my daily driver and it runs 13's and is nearly stock and quite reliable. I shouldn't be modifying it at all or I'll have three hotrods and no reliable cars.
My point is not everybody is trying to turn their f-body into the fastest car they can. Some of us need something to get to work with.
Trust me on that one. Here in the Seattle area most of my driving on the interstate is between 60 to 70 mph, very seldom do I get an opportunity to go over 70mph. Gear sets for a 10 bolt are cheap compared to other mods. Once I figure out what gears I want for sure then I can get a 9" moser or a 12 bolt. Next week I'm going to have a set of 4.10s installed
then I'll know for sure. I'm curious to run the 4.10s on the highway and @ the track. I'm wrestling with the same question. The Camaro isn't my hot rod, it's my work car. Less than 200 RPMs isn't really much difference. I think I'd be disappointed unless I did the 3.73. Definitely noticeable, but not obnoxious.
Thanks,
Steve
This will keep your set up streetable than 3.23's and a converter. I have 2 hotrods (both run 9's), my f-body is my daily driver and it runs 13's and is nearly stock and quite reliable. I shouldn't be modifying it at all or I'll have three hotrods and no reliable cars.
Because I want it go to faster. Duh
> Or, better yet, why even have a performance street car if you have 2 9-second 'hot rods'?
Because at some point they get unreliable, and then you end up driving a slow car. Then you want to make the slow car faster so you dont lose races.
You new here or somethin?
