Help with 9" purchase
I have also called and received quotes from 5 different sponsors on this purchase... some where
in their prices and some were real good!
I am simply a consumer doing research.More importantly I am trying to get all of my facts in line and then share them with the other members on this board who may have a similar application.
Currently this is what I am looking at (prices vary depending on sponsor):
Moser 9" setup with 4Ch ABS
I am currently doing research between the True-trac instead of a Detroit Locker because I have an M6 (PLEASE ALL OPINIONS WELCOME ON THIS!!!)
I am also trying to determine the need or advantage on having the relocation brackets welded on (INPUT WELCOME HERE AS WELL PLEASE!!)
What spline should I use? 31? 35? Advice with Advantage and Disadvantage is appreciated!!
I have not had anyone that says I need to have the TQ arm replaced so I think I may pass on that for now...
I have decided to go with the 9" vs 12Bolt because the TONS
of feedback about the loud rear-end in the 12Bolts...I already have the Trailing Arms and Panhard bar... BTW thanks for the input on the necessary Sway Bar relocation!
I intend to run a 3:50 gear ratio because I am doing a boosted application..
Scott and other members have been very helpful with advice!!! Thanks guys!!
Oh and to answer the other question... I am hoping to put down 500RWHP and apx 600Lbs of TQ (I am not sure how accurate my estimate is)
Thanks again all!!!
NON-LOWERED vehicles will also see a dramatic increase in traction by lowering the rearward angle of the LCA with our relocation brackets. The lower mount holes are placed in the arc pattern of the OEM length LCA. Therefore allowing a non-lowered F-Body to drop the rear LCA angle and NOT require a longer than OEM LCA. All geometry is correctly maintained. The anti-squat performance is providing most users with a full .10 or better 60' reduction!
Slowpoke.... I think 600-650 Pounds of TQ? (I think) And you think I may need a TQ arm? At what HP or TQ do I need that? Any reccomendations of brand or design?
I went with the True Track like Scott recomended and i am 100% pleased i will never go back to posi (clutch packs) it feels great.
As for spline count get what you need spline count has to do with HP TQ and weight of the car. If memorey is with me here i think 31 spline will hold 700hp (correct me if i am wrong) so why add all that rotating weignt it is over kill. It is all your decision though if you plan on having a 8 sec drag car then go for it now.
Good lock with your ride you will love the 9"
CMC
http://www.strangeengineering.net/catalog/index.html
To the user, if you want working ABS/TCS you might want to get 33 spline 12 bolt with the upgraded HD posi. Pricey but it's a good setup. I would get one from Strange from Billingsley or whomever carries Strange.
Bruce
... and that was supposed to be a sale! I am tryng to get a full set-up for closer to the 2k mark then the 3k mark!
I have talked with 5 sponsors as well.
. I did spec the 1350 yoke and crossover U-joint and the 1/2" studs
. If anyone on here is interested and wants to maybe save some money. Stock length housing w/31 spline axles, TCS rings, brake backing plates, bearings (one set pressed on + complete spare set), 1/2x3" studs. Also has LCA relocation brackets and swaybar brackets welded to rear end. Just add a center section setup for 31spline axles and you're on the road. PM me if interested.
What is a solid pinion spacer and crossover U-Joint?
