Does anyone have lockup Problems with BIGGER cams???
Old Jan 15, 2002 | 11:34 AM
SSBoy's Avatar
Default Does anyone have lockup Problems with BIGGER cams???
Im looking at a cam with a duration over 220/220 56X lift and 114lsa , and was wondering if anyones converter didn't lock up with some of the bigger duration cams out there. just wanna hear some feedback.
thanks
[ January 15, 2002: Message edited by: SSBoy ]</p>
Old Jan 15, 2002 | 04:05 PM
SSBoy's Avatar
Default Re: Does anyone have lockup Problems with BIGGER cams???
ttt
Old Jan 15, 2002 | 04:16 PM
No Patience's Avatar
After reading all the posts relating to the converter lockup issues with big stalls (>3500) in cars with cams, the PO300 missfire code IS the cuprit. Your second option instead of going to ED is to wait for LS1 EDIT to come out.
Old Jan 15, 2002 | 10:05 PM
DanZ28's Avatar
I had lock up problems because of the misfire code as well. Had misfire's turned off and cured that problem. BTW, it doesn't need to be a big cam to set this code.
Old Jan 16, 2002 | 12:30 AM
StreetStalkerZ's Avatar
I had lock up problems daily with my B1 cam and stock tuning. I heard that the L Trims have to do with it also because of the stock tuning. With the Ed Wright tuning i have zero lock up issues.
Old Jan 16, 2002 | 12:35 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I don’t know about Ltrims, but I can guarantee you that with a bigger type cam that nasty PO300 (random multiple misfire code) code will cause lock-up issues. I’ve never heard of anyone having lock-up issues due to a cam once that code was removed via a custom tune. I had MTI remove it from my PCM, they said that would keep the ‘verter locking. They never said anything about Ltrims. I haven’t put the cam in yet though, so I don’t know for sure yet. But this is the first I’ve heard about Ltrims (too high or too low???) causing the issue.
Old Jan 16, 2002 | 12:48 AM
SSBoy's Avatar
good good...keep em rollin..FYI i do have Custom Tuning through E. WRight
Old Jan 16, 2002 | 12:59 AM
Joe99SS's Avatar
EW tuning with a 228/228 112lsa cam here and no lockup problems at all with a ST3500 converter.
Old Jan 16, 2002 | 02:11 PM
Ragtop 99's Avatar
EW should be able to get your converter to lock-up right.
LTRIMs and Misfires can both effect lock-up.
Old Jan 16, 2002 | 02:18 PM
RPM WS6's Avatar
[quote]Originally posted by Ragtop 99:
<strong>
LTRIMs and Misfires can both effect lock-up.</strong><hr></blockquote>
Ragtop, please explain to me what about the Ltrims effects lock up? I’d like to know incase I have any issues even with the PO300 removed. I’ve never heard of this happening until this thread, so please enlighten me as to what needs to be done with the Ltrims to fix this. I think EW sets the Ltrims at 0 permanently, leaving the Strims to do all the work, correct? But with a stock tune they move around, and it doesn’t seem to be an issue <img src="images/icons/confused.gif" border="0">
Please make me “informed” <img src="gr_stretch.gif" border="0"> Thanks...
Old Jan 17, 2002 | 07:43 AM
RPM WS6's Avatar
TTT for Ragtop...
Old Jan 17, 2002 | 07:52 AM
Ragtop 99's Avatar
If your LTRIMs are messed up, the perceived load and fuel trim cell being used can be off. This can effect when the computer calls for lock-up and how much line pressure the computer uses to hold lock-up.
Old Jan 17, 2002 | 07:58 AM
RPM WS6's Avatar
<strong>If your LTRIMs are messed up, the perceived load and fuel trim cell being used can be off. This can effect when the computer calls for lock-up and how much line pressure the computer uses to hold lock-up.</strong><hr></blockquote>
But what do you mean by "messed up"? Always maxed out at 25%?
