them 4.30s just aren't enough gear....ordered a new set of "dump-truck" gears....
LS1Tech Premium Sponsor
Chris - I have the same 26x9x15" Hoosier slicks on the way, and I'm mounting them on 7.5" rims. The recommended rim width is 7-8" according to Summit's catalog. I was wanting to go no larger than the 7.5" Convo Pro w/ the 5" BS so it would tuck up under the fender nicely. <img src="gr_stretch.gif" border="0">
I thought the 7.5" Convo Pro w/5" BS sticks out? And you have to roll the fender lip?
Rick
Rick
If you get a GM 8.875 "C" Axle you can go upto a 6.14 gear. here are the part numbers
Pro Gears are specifically designed for drag race only. The Axles were used in these cars.
10 7/8" * Oval Cover 12 Holes
8.875" Diameter Ring Gear * 30 Splines
1.625" Diameter Pinion * "C" Axle Only
Make Year
Chevrolet 65-72
Chevelle 65-72
Chevy II 65-72
Camaro 67-72
GTO/Firebird 70-72
Nova 70-72
Olds F-85 68-69
El Camino 65-72
Ratio Teeth Part No.
4.11 37-9 79-0099-1**
4.33 39-9 79-0074-1**
4.56 41-9 79-0072-1**
4.88 39-8 79-0064-1**
5.14 36-7 79-0027-1**
5.38 43-8 79-0029-1**
5.57 39-7 79-0031-1**
5.86 41-7 79-0033-1**
6.14 43-7 79-0035-1**
Make Year
Chevrolet 65-72
Chevelle 65-72
Chevy II 65-72
Camaro 67-72
GTO/Firebird 70-72
Nova 70-72
Olds F-85 68-69
El Camino 65-72
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
so does the 9" Ford <img src="gr_grin.gif" border="0">
No manly 6.50s for me <img src="gr_eek2.gif" border="0">
