TCS Module????
Old Aug 1, 2005 | 04:11 PM
UnZFeat'd's Avatar
Default TCS Module????
hey, i was going to buy one of those TCS modules from SLP for my 98 Z28, since it doesnt have the switch to switch the traction control on and off. I was wondering if anyone out there has bought this and installed it themselves? and if so, how long did the install take and what did you have to do? Thanks!
Old Aug 2, 2005 | 09:32 AM
ls2 bait's Avatar
it takes 36 seconds. all u have to do is pop off the radio bezel and unplug the switch then plug that one in between the switch and the factory plug then pop the bezel back on. it couldnt be any easier to install. good luck.
Old Aug 2, 2005 | 10:13 AM
kp's Avatar
kp
If you dont have the switch you most likely dont have traction control. Not all cars had it, if it has a little electric motor looking thing behind the battery with three cables going to it the car has traction control, if it doesnt it doesnt
Old Aug 2, 2005 | 12:43 PM
ls2 bait's Avatar
and that my friends is how i display my impatience. i didnt read the post just skimmed it and told u how to put it in. if u dont have a switch u dont have traction control. its always off
Old Aug 2, 2005 | 01:24 PM
UnZFeat'd's Avatar
i thought all Z28s in 98 came with traction control, just not the switch.
Old Aug 2, 2005 | 02:54 PM
kp's Avatar
kp
Possible I guess, only had one 98 SS and it had the switch, so did my 98 TA. It was on option in 98though and not standard as far as I know but I could be wrong, if it has the TCS motor under the hood it has it - easiest way to know
Old Aug 2, 2005 | 03:29 PM
00BlackSS's Avatar
i have no switch and no module on mine!!! only have a low trac light when i spin my tires :driving:
would i not have to get the tcs hook up on a 9'' then since i dont have tcs???
Old Aug 3, 2005 | 01:30 AM
kp's Avatar
kp
They dont make a non-tcs (3 channel) 9" rear unfortunately, if you wanted to keep your ABS/TCS you would have to get a 12 bolt. A few people have used a wheel and sensor on the pinion on a 9" but its something you would have to make yourself.
Old Aug 3, 2005 | 05:50 AM
00BlackSS's Avatar
soo i need a 3 channel then??? and i found this site that has em
http://www.driveline-solutions.com/s...oduct=Rearends
ur saying that this will work then with teh 3 channel???
