ABS INOP and TCS OFF
Next day I removed the speed sensor from the rear end and clean all the metal shavings off. Get in car, both lights are on but after driving about 30 seconds, they go off. I think "great!" Well about 5 minutes into the drive, they light up again.
Today, every time I start the car, they are on, turn off after 30 seconds or so and come back on after 5 minutes or so.
Diagnosis anyone? Both speed sensors are securely plugged in and clean. I haven't checked if the wires to the sensors have melted or snagged or anything, but anyone else have some suggestions?
Sometimes the sensors need to be spaced out a little, the wheel studs interfere with the reluctor and it freaks the ABS module out. Maybe they were spaced before and they took the washers out. Usually a couple washers to space the sensors a little toward he inside will fix it. Could have also damaged one of the sensors also..
I have a pretty good feeling that the backing plate and reluctor ring are too close to the axle hat. I noticed while putting everything back together yesterday, when the caliper was on the rotor, it was spaced a little bit back from the backing plate. That would suggest that the backing plate is too close to the axle hat. I'll take some measurements tomorrow.
I do get a Low Trac light........ at 120mph at 6,000 rpm in 3rd gear. Maybe I'm starting to take off
. You need to space the sensors.
