witch option for 9" third member?
Old Aug 4, 2005 | 07:37 PM
TTSSZ's Avatar
Default witch option for 9" third member?
What’s the best setup on a 9” rear for a 02 SS 85% street car, 10% road course, 5% drag.
I was told to get a true track.
I had a Detroit locker in my 71 it did not last long, before I knew it I was doing 1 wheel squealers. You just can’t do that in front of your friends, not in a decked out supercruzer.
Was also told the posi would not be the best choice for the road course. I have a posi unit in the 71 now and I love it. I didn’t notice a handling difference with it.
I think it’s when you come out of a corner hard on the throttle that the posi has a tendency to want to brake loose and go sideways?
Looks like I’m going with a Moser housing and axels…..31 spline….. street nodular iron case, not sure how much HP the aluminum case can hold. Alum. pinion support, ect.
The car is pushing 5 and ¾ at the wheels at low boost but the rear will have to handle about 750rw after I get a forged short block.
Posi?
Detroit locker?
Air locker? (not even sure what that is)
True track?
Other suggestions?
Any info will be greatly appreciated.
Old Aug 4, 2005 | 09:47 PM
3rdgenguy's Avatar
an air locker is esentally a open diif that has a set of gears the locks in which is activated by an onboard air supply. u have an open diff most the time but when activated u have essentuall a spool great for drag racing. if u r goin with the 31 splines depending on how hard u are going to be with the car i dont think they would break as easily as the stockers if you forgot to unlock the diff and go around some corners. you would more then likely tear up tires and have an annoying hop formthe wheels going around a corner
Old Aug 4, 2005 | 10:37 PM
bigdsz's Avatar
IMO the Detroit True Trac is your only option. for drag
i've got the
detroit locker but it's only good for drag, but it hold s like a ****.
The truTrac is much more forgiving but still holds well.for road coarse.
Old Aug 5, 2005 | 10:03 AM
chicane's Avatar
If you had a Detroit Locker and it only spun one wheel.... you had more problems than just that.
An ARB (airlocker) wont live at that power level.... nor will you like replacing the 'umbrella seals' as often as you will.
There is nothing wrong with a Locker on a road course, there are plenty of them out there and they have been used in road racing since the middle 60's without many problems. With your previous statement, I guess you havent found someone that will set it up correctly for you ?
A True Track or a Diamond Track are really your only choices from there at the described power level with a 9" center section.
An alloy case will hold up just fine..... if you can find someone that has had enough experience with them to set it up correctly for the intended application. I have put them in various chassis with more power to the ground than what you have described and havent had any problems with them, set up the right way.
Another option you have is to run an alloy 12 bolt center section with an Eaton limited slip with the 800lb preload. Not only is it tunable but it is rebuildable and its the strongest thing out there next to a Detroit Locker..... plus its street and parts friendly..... and a 12 bolt pinion centerline is more efficient than that of a 9".
If you want something done right, look to shop that actually has high standards.... someone like Mark Williams maybe ?? Or a independant builder like Pro Gear or Tom's Differentials or Hughes Differentials in San Diego..... and if your not happy with one of them, call me.
But if you were going to run a 9" center section.... and it was up to me..... I would run a Torsen TBR . IMO, there is nothing else for a dual or triple purpose chassis especially with the amount of street use you have stated.
Old Aug 5, 2005 | 04:32 PM
Tally TransAm's Avatar
you have three options
mostly drag racing: spool
Street/strip: locker
mostly street/some strip/autocross: true trac
Old Aug 5, 2005 | 08:41 PM
TTSSZ's Avatar
I'm sucking this all in like a sponge..........
Thanks for the help.
I'll let you know what I decide.
1 week without the rig and I'm hearting bad.
Got blasted off a light yesterday by a cobra,
my 220,000 mi. tacoma just don't got it.
All I could think about was doing a GN v6 swap in it.
Old Aug 5, 2005 | 08:53 PM
chicane's Avatar
15 lbs of squirrel on a Toyota 3600 and the Cobra will have its hands full trying to find its self........
Old Aug 8, 2005 | 07:34 PM
FaSS Blac's Avatar
I agree with Tally Trans Am. I just put in a Billingsley 9", 3.70 gear, Trae Tech 31 spline soft locker and love it!!!!!! Just don't gas it too hard in sharp turns and you'll barely notice it. It is kind of tricky in the rain going around slow turns or turns from a standing start. The inside tire WILL spin no matter how easy you apply the gas. This is only on slick surfaces. Other than that, when I put the line lock on, I'm reward with a nice, even two wheel burn!!!!!!!!!! I fought the stock 10 bolt for years to acheive this to no avail. I finally gave up and now the 10 bolt is quietly sitting on the side of the house, waiting to be stripped of all its salvagable parts, and ultimately awaiting its final, long deserve rest, in the Columbus Landfill along with the rest of the GARBAGE!!!!!!!!!!!!!!!! I really, really hate that rear!!!!!!!!!!!!!!! 10 bolts suck!!!!!!!!!! 10 bolts make normal, law abiding people, go Anakin Skywalker on a ****!!!!!!!!!! I'm done. I feel much better now.
