gear ratio for 12 bolt
I was under the impression that the gear ratios available for the 12 bolts were 3.73 or 4.11.
I was just looking through a catalog and saw 3.90 gear & pinion set for 12 bolt car, made by richmond gear. I figured I would ask about it. Would these be a good compromise between the other 2?
Thanks,
Jeff
Thanks,
Jeff
Re: gear ratio for 12 bolt
3.90 is a good choice for an A4 with a small cam where you don't want to go above 6200/6300 rpm.
I was going to get it, but decided on 3.73s for a little room on the spray if I went that way.
