pinion seal problems
Old Sep 15, 2005 | 09:32 AM
Mike2000Z28's Avatar
I just blew mine out cause my driveshaft blew is joints flat in both the front and rear. It sucks.
Old Sep 15, 2005 | 10:22 AM
00T\A's Avatar
I 'am on my third one in about 5 years so i guess i am doing pretty good
I sure wish there was a permamant fix though
Old Sep 15, 2005 | 10:54 AM
methane's Avatar
well i just got back from the PONTIAC dealership (i went in for a leak coming from the rearend) and there anwser was.... we're not sure why its leaking, we're going to call our tech support dept. and get back to you.
Old Sep 15, 2005 | 11:12 AM
jyeager's Avatar
I'm sure the guy that started this thread has a legit problem, but just for the sake of anyone else happening along I'll point something out:
A lot of 'leaks' are really fluid coming out the breather at the top of the pumpkin. Perhaps even enough to drip on to the ground, but mostly it's seen as a wet stain on the housing. You can tell where the fluid is coming from by looking for a thin transverse line of fluid on the underbody (which indicates pinion seal) or just a broad stain all around (breather hole).
If it's the breather, that can either be ignored or solved via a longer breather tube.
Old Sep 26, 2005 | 12:24 PM
luvmeZ28's Avatar
had mine fixed again, and another time, and it leaked again both times . been leaking ever since. a guy i know that has a shop told me to bring it to him, so i did. he took it all apart and actually cleaned everything up and looked at it. it turns out my yoke was all pitted up. how does that happen? i went and got a spare yoke out of a buddy of mines extra rear, so i guess tommorow i will finally see if my woes are over.
Old Sep 26, 2005 | 12:28 PM
jyeager's Avatar
Unless I'm misunderstanding, I don't see how the yoke could be a problem. It doesn't touch the pinion seal does it?
Old Sep 26, 2005 | 12:31 PM
ss1129's Avatar
mine leaks like a bitch too. Never been apart..that I know of. Isnt the point of the seal to go around the yoke?
Old Sep 26, 2005 | 12:41 PM
jyeager's Avatar
No, the seal goes around the pinion shaft, the yoke bolts on to the splined end of the pinion shaft. The yoke is what the u-joint bolts in to.
Old Sep 26, 2005 | 12:51 PM
ss1129's Avatar
gotcha...so is it a bitch to change out?
Old Sep 26, 2005 | 01:21 PM
Not really, sometimes if the shaft is out of balance and/or bad ujoints you may wear a grove in the yoke pinion shaft and that will cause the pinion seal to leak.
Old Sep 26, 2005 | 03:58 PM
luvmeZ28's Avatar
there isnt a groove in the yoke on mine, its got little pits all over it, and there doesnt seem to be a pattern.
