pinion seal problems
sorry for the rant, just wanted to know if this was common. the shop i had do it the first time is supposed to be the best around here, and the guy who did it the second is supposed to be the best guy, period. so i dont think its because they dont know what they are doing.
Simple steps to take to insure a leak free seal:
1) Clean all parts involved and I mean REALLY clean
2) Scotch brite the yolk seal surface (or emery/crokus cloth)
3) Apply sealer to the outside of the seal and the splines in the pinion yolk
4) Apply grease to the seal surface and to the seal surface of the yolk
5) Use red locktite to the pinion nut and stake the nut when complete
6) Let sealer 'skin' before you add lubricant
7) Stay away from thinner lubricants, use a minimum of a straight weight 90 or 140
If it leaks after they replaced the seal, they would be liable to fix it until it doesnt. Well, at least that is how I do business.
the next morning i go to see my car has a nice sized puddle under it, so i look and its the pinion seal. i took it right up there and demanded they fix it and they did. but about a month later it started whining like all heck and i called them, and i was "out of luck".
so i just got toby harl(or harlson)-sorry toby!-to rebuild it for me. and it turned out it was the inner pinion bearing. he fixed it, sounds great, but he messed up on the pinion seal. no biggie, it was a quick fix for him, and it now appears my rear end woes are over. and toby is the man. he does all his own work and he won the top truck challenge a few times(national comp), i think, that the 4 wheel drive magazine(4 wheel and off road?) puts on every year. his orange blazer was a monster.
will dealers uninstall options?
OH, AND GUESS WHAT GUYS, I JUST LOOKED UNDER MY CAR LAST NIGHT, AND ITS LEAKING AGAIN!!!!!
thats two people that have had problems with my pinion seal. seems strange.
thats two people that have had problems with my pinion seal. seems strange. They are a one time deal.
Have him put in a solid spacer they tend to help with the leaky F-body seal syndrome
Best of luck.
just some of the problems
