noisy posi.
Old Sep 20, 2005 | 05:43 PM
slimcracka's Avatar
Default noisy posi.
ok i got a factory rearend... factory gears posi everything... just bought the car about a month ago... im new to the whole camaro thang... a couple buddies of mine say that they make noise they all do its normal.. well while drving straight you can hear a clunk clunk clunk clunk about one a sec.. you can hear it good while slowing for a redlight..well when turning into a parking space it gets louder and faster.. is my rearend or posi goin out or is this normal..im thinking i might just get the fluid changed...and dont worry about it untill it breaks.. but what do yall think... inlighten me please
justin
Old Sep 21, 2005 | 01:51 PM
SLP4CamaroSS's Avatar
i would check the fluid first but it soudns like u need a new posi
Old Sep 21, 2005 | 02:02 PM
rotwiler's Avatar
It does sound like the posi may be broke. Do both wheels spin when holding the brakes? My stock rear I added 3:42's and they whine, but never hear a clunk clunk.
Old Sep 21, 2005 | 05:25 PM
slimcracka's Avatar
it kinda sounds like when a pad is staking around in the capiler but i hope it ante the posi i cant aford a new one.... if it is whats a good one to put back in there?
Old Sep 21, 2005 | 06:48 PM
slimcracka's Avatar
if it is the posi is this a good deal or what.. thanx again guys..
http://cgi.ebay.com/ebaymotors/POSI-...QQcmdZViewItem
Old Sep 21, 2005 | 07:10 PM
00PewterSS's Avatar
Take the cover off and find out what you are working with. If it is clunking that much it probably won't be difficult to see if there is something wrong.
Brian
Old Sep 21, 2005 | 07:11 PM
slimcracka's Avatar
what will i be looking for?
Old Sep 21, 2005 | 08:13 PM
SporkLover's Avatar
GM says that the Posi on a 99-02 car makes some clunking sounds on decel and going slowly around a turn. I say pull the cover and look for loose metal, gears missing teeth, or any other suspect foriegn objects.
If everything looks ok... try new fluid, and add GM posi additive
Old Sep 22, 2005 | 07:41 PM
slimcracka's Avatar
thats what its doing exactly on decel and around a slow corner like turning into a parking space...ill look at it the fluid is a lil dirty so ill change it what kind do yall recomend and what additive..thanx again
Old Sep 22, 2005 | 08:56 PM
transfan0186's Avatar
It is a limited Slip-Posi. It is the posi slipping simply put. Don't forget to put the limited slip fluid in when you change your fluid or you may have more problems. It is annoying mine does the same thing.
