strange 12 bolt guys need your help...
Originally Posted by 1320_PERFORMANCE
Wassup Rex...dont really know what place on Oahu, they just gave me a # and a name....I guess if my rear fails on me again Ill have to do all the work again myself....I think they should send me a new set of gears, innner and outer pinion bearings & races, carrier bearings and races, pinion nut & seal, solid spacer and gear lube + additive just incase the rear ***** up again ....
I bet its either that place I mentioned or 4wheel parts located in waipahu.again good luck on fixing it or have somebody fix it.
Originally Posted by Ziptie
This really concerns me (bolting my dana 60 in tomorrow.)
I recommend that anyone thinking of buying from strange read their "warranty" very carefully.
Good Luck with yours.
DJ
I got my Dana installed. So far the only real issue is the ABS doesn't work. I called them up and they suggested to pull the cover and make sure the reluctor ring is there. They said if it's not, they will have someone in town fix it for me. I gotta say if they own up to that it's pretty impressive...compared to other stories I've heard.
I got mine from Tbyrne motorsports. The only issue I had with T-Byrne was the girl I was talking to didn't see very knowledgeable on the product...and when you are spending 2500+ on something it would be horrible if something came mis configured and it needed to be sent back. She also had to call me back on many questions I had. But, He got me a great deal slipping me into the GP, way past the due date.
Originally Posted by Fedge
so is Moser any better? I just didn't like the fact I would hafta send my axles to Strange just keep my exciter rings for the ABS/TCS
#32
Kleeborp the Moderator™
great. that's just wonderful. I guess I will just hafta spend the 3 effing grand and then have somebody go over it with a fine toothed comb
#34
Originally Posted by 99zman
you can't buy quality **** these days, im on the search again for a perfect of rims??? ya sure.
#35
Originally Posted by MeentSS02
You hit the nail on the head there...hell, I don't even drive on my CCW rims anymore because they are too hard to keep clean under daily driving conditions. I'm waiting to get them chromed...AFTER I get this rear end squared away.
#36
how much do those ccw's run pricce wise? if you dont mind me asking? pm me if you dont want to post it up? they sure do look sweet as hell.
#37
Let me just put it this way - price a fully optioned Strange rear end (like I currently have in my garage). That was the price for just the wheels (maybe a little more if you got a deal on the Strange). Tires are pretty steep too
#39
I shoulda said "no" to my car a loooooooooong time ago
Thousands of dollars later, and still not satisfied
It just never ends does it?
