Upper Panhard Bar??
Old Feb 12, 2002 | 06:26 AM
01 SS Jay's Avatar
Default Upper Panhard Bar??
What exactly does this thing do. Ive read where several people on here have taken theirs out, and I would like to take mine out for true duals, if it wont hurt anything. Thanks
Old Feb 12, 2002 | 10:47 AM
Colonel's Avatar
Default Re: Upper Panhard Bar??
I don't think it does a thing in a straight line. Now when cornering hard it helps to keep everything tied together.
I've had mine removed since last summer with no problems but I drive in a straight line %95 of the time. <img src="gr_grin.gif" border="0">
Old Feb 12, 2002 | 10:54 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
It has to be for handling, perhaps loading the rearend around corners or something.
I have had mine out since September. I don't take corners hard at all, I have skinnies up front too.
Old Feb 12, 2002 | 11:23 AM
Colonel's Avatar
PSJohnnyboy, did you weigh your brace? I did but I don't remember if it was 5 or 8 lbs. I think it was 5.5.
Old Feb 12, 2002 | 11:28 AM
Terry Burger's Avatar
More like 3#.
Old Feb 12, 2002 | 11:39 AM
WILWAXU's Avatar
Hmm.. guess I have a new canidate for removal <img src="gr_images/icons/wink.gif" border="0">
Old Feb 12, 2002 | 03:12 PM
mmiller's Avatar
Texas Director
I just removed mine when I installed the 1LE rear sway bar and urethane end links. After looking at it, I don't really see what it does, or what it would hurt to remove it.
Old Feb 12, 2002 | 03:38 PM
LS1Tech Co-Founder
5-6 lbs I would say.
Old Feb 12, 2002 | 04:18 PM
Magnus's Avatar
LS1TECH Sponsor
I also have wondered about this.... very interesting. I think I'll be removing mine.
Old Feb 12, 2002 | 06:06 PM
Bob2of3's Avatar
Wheels up Director
Once I get the front end out of the air that thing is history <img src="gr_images/icons/wink.gif" border="0">
LAter <img src="gr_grin.gif" border="0">
Old Feb 13, 2002 | 02:45 AM
Dope's Avatar
As far as I remember, it's a brace for the lower panhard rod (the one that actually attaches to the axle). Under heavy cornering it can flex. In fact, some of the autoX and road racers guys have welded in a stronger brackets because even with the brace, they are getting too much flex. If you think about it ,the panhard is about the only thing preventing the axle from moving left/right from under the car. Under heavy cornering that's a LOT of stress!
I wouldn't worry about it unless you race competitively (on tracks that have corners that is).
Dope
Dope
Old Feb 13, 2002 | 06:25 AM
01 SS Jay's Avatar
So basically I should upgrade the stock main panhard, then shitcan the other one. Perfect, thanks guys.
Old Feb 13, 2002 | 10:27 AM
Colonel's Avatar
Correct.
Jay Billingsley, one of our sponsors, makes a VERY lightweight but VERY strong chromoly panhard rod. <img src="gr_images/icons/cool.gif" border="0"> I don't know the priceing though. You might give him a call. I have his chromoly LCAs and man these things are SWEET! They are 5 lbs lighter EACH than the Hotchkis LCAs I was running before. <img src="gr_images/icons/cool.gif" border="0">
Old Feb 13, 2002 | 01:28 PM
SSG-Z28's Avatar
So is that the deal with chromoly? Lighter, yet stronger?
Thanks!! <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Feb 14, 2002 | 12:21 AM
Onyx LS1's Avatar
ooh looks I'm gonna pull that sucker off too.
Old Feb 14, 2002 | 12:51 AM
Raughammer's Avatar
D(irecto)r Pepper
Gone, been gone. Good riddance.
I wonder where MMiller got the idea? <img src="gr_grin.gif" border="0">
Old Feb 14, 2002 | 10:59 AM
Colonel's Avatar
Chrome moly isn't lighter than steel by volume but it is stronger which means you can use less of it to get the same job done (as in using thinner walled tubing.) And that DOES mean lighter. <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Feb 15, 2002 | 12:14 AM
01 SS Jay's Avatar
If i had of known this before, id already have true duals ran. I wonder if a normal mild steel one will do the trick. I dont autox, but i will take an exit ramp pretty hard..
Old Feb 19, 2002 | 09:48 PM
MIGHTYMOUSE's Avatar
wierd... i forgot totally about that thing... its the one thats always in the way when im f'ing around under the gas tank.. hmm..
Old Feb 20, 2002 | 10:36 AM
LS1Tech Co-Founder
I have been running with !UPB, and with a stock lower.
I just purchased a used Hotchkis lower just to be safe.
I'm not sure about cornering, I take all corners slow.
