How do get rid of "ABS INOP"?
Old Nov 2, 2005 | 07:27 AM
ibanezrg770's Avatar
Default How do get rid of "ABS INOP"?
Hi,
I installed a 9" in my car and would like to disable the "ABS INOP" light. I heard it takes a resistor, can anyone give me details? Thanks in advance. Timmay!!!
Old Nov 2, 2005 | 11:44 PM
MountainMotor's Avatar
I can tell you one simple fix to help with any dash light that might pop up, just reach under the dash and pull out the ABS INOP bulb , just kiddin, I'm not real for sure on the 9" setup.
Old Nov 3, 2005 | 06:26 PM
blue01ta's Avatar
www.sjmmanufacturing.com they're a sponsor. They sell a kit that will eliminate all the abs parts off the car and it comes with a proportioning valve but they say the same thing pull the light out of the dash.
Old Nov 3, 2005 | 07:19 PM
Kewl, looks like I am just going to pull the bulb then. Thanks for your help. Timmay!!!
Old Nov 3, 2005 | 09:49 PM
code4's Avatar
When I pulled my dash out I didn't know which and or how to pull the bulb so I just put black tape over it. It is hard to see the tape under the glass.
Old Nov 4, 2005 | 10:11 PM
rufretic's Avatar
It's even harder to see if you put the tape on the other side of the overlay, more like you cant see it at all. Thats what I did for my tcs light and plan to do the same for my abs light.
Old Nov 6, 2005 | 12:59 PM
I did the tape mod. Only took 20 minutes. Thanks guys. Timmay!!!
Old Nov 6, 2005 | 07:12 PM
LETHL_SS's Avatar
I just grabbed some pliers and ripped out the bulb
Old May 19, 2008 | 06:50 PM
mvrotc's Avatar
will the car pass inspection with the bulb pulled out?
Old May 19, 2008 | 09:43 PM
dpinson's Avatar
i called an inspector and they said it would pass even with the abs inop light on as long as the regular brake light wasnt on
Old May 19, 2008 | 10:26 PM
Tally TransAm's Avatar
i believe the proper term for the procedure is called a bulbectomy
Old May 20, 2008 | 04:53 PM
SparkyJJO's Avatar
They don't look in your dash for missing or burned out bulbs do they?
Old May 24, 2008 | 06:42 AM
ShevrolayZ28's Avatar
I didn't try to remove the bulb as it is soldered into the board. I used electrical tape and I painted the bulb with black high-temp paint. Now, you can't see it at all.
https://ls1tech.com/forums/showthrea...t=#post9191033
