Insurance Buys Me Rear End
Old 11-10-2005, 09:36 AM
mustgofasster's Avatar
Default Insurance Buys Me Rear End
Hey guys, I recently was hit by some old man, and my rear diff case got cracked. The people over at Haddad Motorsports told me I need a whole new rear end. So my question is which one should I go with? I know a 9inch is the most strongest but I have an A4 with around 500RWHP. I was thinking a 12 bolt should be plenty.
Old 11-10-2005, 10:42 AM
LiquidSword's Avatar
12 bolt.
Old 11-10-2005, 12:32 PM
Krab's Avatar
Since you have an A4 and it's easier on the drivetrain, I'd get a 12-bolt that way you can keep the driveability of the stock 10-bolt and still beat the crap out of your car.
Old 11-10-2005, 12:41 PM
TRex's Avatar
12 bolts are more efficient and lighter, however I am not aware that anyone offers a bolt in 3 ch. (abs only) solution.
9" is heavier, uses more Hp to turn, but is stronger, and offers the ability to easily swap gear ratios via a chunk (diff, gears, pinion) change in about 1-2 hrs. Also easier to get a 3 ch ABS setup going.
Either works fine with TCS
Old 11-10-2005, 01:55 PM
NumberOneSled's Avatar
Moser and Strange offer 3 ch. (abs only).
Old 11-10-2005, 02:02 PM
Krab's Avatar
Actually, you've got it backwards. 12-bolts can be used with either ABS (3-channel) or both ABS & TCS (4-channel). 9" rears can be used with TCS, but not ABS alone.
Old 11-10-2005, 02:36 PM
TRex's Avatar
Oh yeah, thanks for correcting me. What do they use for the reluctor ring on the 3 ch 12 bolts ?
Old 11-10-2005, 04:33 PM
Gary Z's Avatar
They use a reluctor ring.
Old 11-10-2005, 06:40 PM
TRex's Avatar
On the diff ? Do they make it themselves ? Does it fit on a standard diff or does the diff have to be custom machined ? Is it only available on certain diffs, or any diff ? Does it bolt on, weld on, or press on ?
Sorry to ask so many questions, but I have been all over their web sites and never seen anything on this
Old 11-10-2005, 08:00 PM
Krab's Avatar
I'm pretty sure it's like the stocker, where it gets sandwiched between the carrier and the ring gear.
