What type of 12 bolt?
Old Nov 20, 2005 | 01:18 AM
Shamson5.7's Avatar
Default What type of 12 bolt?
So I went to the moser site to look at prices of the 12 bolts...I didnt realize there were so many options! Im looking to do a full 12 bolt setup from a 10 bolt stock rear end. Any information would be great on what to get. I have a 98 ver TA with traction control and M6 with spec 3 clutch.
Old Nov 20, 2005 | 04:59 AM
EPP's Avatar
EPP
Here is what I recommend below. As far as gear ratio's go, I would go with 3:73 gears for automatics that see highway use. 4.10's for six speeds. This is just a general rule. If your car is making 500+ rwhp, 4.10's may not get you through the 1/4 mile, depending on tire diameter and engine rpm. Bob
Moser 12 bolt with True Trak posi, your choice of gear ratio.
Moser 33 spline 10 year warrantied axles.
Moser ABS or ABS/TCS.
Moser performance (TA) cover.
Moser crate fee.
Rear end is shipped two days after order is taken. $2350.00 + freight collect.
Freight cost is normally $65.00 to $150.00, depending on location from Indiana.
We are located approx one hour away from Moser, which has resulted in us having a very good relationship with Moser. Bob
Old Nov 20, 2005 | 11:47 AM
Shamson5.7's Avatar
Looking at your website here, it says to select the gears that I prefer...I dont see any 4:10s. I see 4:11s am I just not looking at the right 12bolt here? And buying one of these will include everything I need to swap over right?
Old Nov 20, 2005 | 11:54 AM
Shamson5.7's Avatar
Oh also my car is lowered about an inch to 1 1/4 is that going to be a problem with the 12 bolt? Ive heard you cant have a lowered car with a 9in so I need to make sure.
Old Nov 20, 2005 | 12:19 PM
J&J Speed Shop's Avatar
Having the car lowered is a not a problem with the 12 bolt. I have a customer with one in a lowered 1LE track car
Old Nov 20, 2005 | 11:29 PM
97 Z Me Go's Avatar
Why the true track over the eaton posi?
Kyle
Old Nov 21, 2005 | 09:11 AM
KCFormula's Avatar
Mosers use 9" axle tubes so they will put your rear end up in the air a little. Many people counter this by taking the top spring perch out and using a section of garden hose to cover the top coil.
Old Nov 21, 2005 | 01:25 PM
Yes I know what they use. I have installed and sold more Moser 12 bolts and 9" rears than I can count. I have a customer I sponsor with a 1LE race car with a 12 bolt. The car is almost on the ground and there are no issues with it
Old Nov 21, 2005 | 04:40 PM
as35thss's Avatar
JnJSpdShop. You site shows abs for a 12 bolt spool. I was told you couldn't get abs with a spool? Is this true.
Old Nov 22, 2005 | 09:47 AM
EPP's Avatar
EPP
Smile
Yes, just call us and we can take your order over the phone. Everything is pretty much included. You will need to purchase 3 qts of non synthetic gear lube, posi additive, 4 bolts for the torque arm, a new universal joint, and a section of tubing for the vent line. Bob
Old Nov 22, 2005 | 10:00 AM
EPP's Avatar
EPP
Kyle
The True Trac made by the same company that makes the Detroit Locker, has proven itself to be more dependable, and won't become a one tire spinner as easily as the Eaton does. I have sold doznes of these in Mosers, and have not had any problems. Bob
Old Nov 22, 2005 | 01:22 PM
Carter Hays's Avatar
Do you still need the posi additive with the True-Trac? I thought it was clutchless. Just curious.
Old Nov 22, 2005 | 04:50 PM
EPP's Avatar
EPP
They are clutchless, but it still tends to make it operate quieter. Bob
Old Nov 23, 2005 | 04:14 AM
Black FormulaLs1's Avatar
the following is a list of my mods..so far my 10 bolt has survived..although 1 axles got bent and the auburn diff grenaded..what would be best for my car? i thought it would be wise to give you info on it nowand see what you thought about it as you install these rear ends..thanks..GRegg
1999 firebird formula-T Top car
101K--77K when i first traded for her..
Onyx Black
LS1
M6
K&N air filter
NGK Plugs
MSD Wires
SLP Long tuber ceramic heddars
SLP Loudmouth version 1
SLP 3.5 chrome Tips
SLP LID
SLP Strutt Tower Brace
Spec stage 1 clutch
Pro 5.0 shifter
Hurst 35th anniv. shifter ****
Skip Shift Eliminator
Bilstein HD shock all the way around
Eibach springs 1.5" drop
Energy suspention bushing kit
BMR Torque arm
BMR Adj. Panhard Rod
BMR LCA
BMR SFC
Richmond 3:73 gears
Auburn LImited Slip Diff
TA Girdle
17x9.5 ZR1 GUnmetal Grey w/ SLP Centercaps (front)
17x11 ZR1 Gunmetal Grey w/ SLP Centercaps (rear)
** rear tires are 315/35/17**
OIL USED- ROYAL PURPLE
FILTER - Fram Sure Grip
Future plans include the following:
SLP Raptor Hood
OL'Lumpy spoiler..( i didnt forget you!!!!)
New Front and Rear sway bars
Fresh Black Cherry or Tripple tuxedo paint
Slotted Rotors
6 piston calipers
SLP's 525 H/C pkg
LS6 intake
BBK 80 mm TB
** maby go w/ an Eaton diff
Old Nov 23, 2005 | 05:29 AM
EPP's Avatar
EPP
The Moser 12 bolt that I spec'd out on page 1 of this thread would be a great way to go for your car. 4:10 gears would give you a little more exceleration over your 3:73 gears. Bob
Old Nov 23, 2005 | 01:38 PM
Yeah that is just an error in the listing. Spool defeats the purpose of ABS
Nope no posi additive necessary because there are no friction plates
Old Nov 28, 2005 | 06:04 AM
01SLPSS's Avatar
I did this, and it works!!!!
I have a M6, Spec 3i Clutch and a 12-bolt/4.10's/33spline/ABS/TCS/TA Support/Eaton!!! Go with a Tru-Trac instead of an Eaton though!!!
