Detroit True Trac in a 12-Bolt?
Is it possible and/or are there any vendors putting these in a Strange 12-bolt?
Also, since a posi is the weak link in a 12-bolt, wouldn't a 12-bolt with a locker be just as strong as a 9" with a locker, not to mention being more efficient and lighter?
Thanks.
Thanks.
The strange 33 spline teeth are not cut at the same angle as the true trac. This according to a tech at strange. Too bad cause I was ready to throw down the $$ and buy a strange unit.
Ah, thanks Racer. I knew there had to be a good reason, I just didn't know what it was.
Looks like I'm back on the 9" again, but too bad about the True Trac not working with a Strange 12-bolt. I knew it sounded too good to be true (trac).
Good question which I'm not qualified to answer, but I understand that the 9" lifts the rear about an inch. It seems that people are using relocation brackets to offset that.
Do you offer Moser 12-bolts with true tracs?
Why do people opt for a 9" when they could get a true trac in a 12-bolt? I know there's a lot of preference for Strange because of the TA mounting situation, but is that the only reason?
Thanks.
Thanks.
I was leaning towards a Strange for several reasons: TA mount, paint, cable mount, sway bar mount, less complaints (at least a few months ago), less money.
In fact, I had arranged to drop ship a true-track to strange for them to install into a rear axle for me. However, I got concerned about being the guinea pig and backed out. Good thing too, 'cause it turns out that it wont work.
Ended up ordering a moser from EPP yesterday w/truetrak. I can get over the lack of paint, brake cable mount, and vent tube. But no sway bar mount still seems rather cheap. Hopefully the TA mounts will work out OK.
In the end it was a trade-off.
Good info Racer!
Once you get everything sorted-out and installed I'm sure you'll be happy.
BTW, could you explain about the "vent tube," "brake cable mount" and how you plan to mount the sway bar. This is the first I've heard about a vent tube.
Congrats on pulling the trigger!
I have just about made my mine up on the same set up. I think I am going to order mine to. I think you made a good selection. It is either this set up or a 9in with a Detroit locker. I just don't want a Ford rear on my car, and I want to retain my ABS. I called Moser yesterday and they told me a 12 bolt with the True Track and 33 spline axle would be stronger then a 9in with 31 spline axles. I thought that was very interesting.
CMC
Originally Posted by Predator
Good info Racer!
CMC
Some people are very happy with their 12 bolts while others absolutely hate them. Its a roll of the dice I suppose, but I cant really recall anyone not being happy with their 9 Inch let alone breaking one. I prefer the 9 inch because if its strength, versatility, and simplicity. But everyone has their own preferences. I am glad that you are one of the lucky ones.
CMC
CMC
Thanks.
Thanks.
A 9" Moser would still be stronger than a 12 bolt, it is just a heavier duty unit, but they are heavier and use up more horsepower. For all but the hardest hitting cars, a 12 bolt will suffice. Bob
Thanks for the info Bob!
This looks like a valid option for someone who doesn't want a traditional posi, and doesn't fit into the "hardest hitting cars" category (which I certainly don't).
Can you use a BMR or Spohn sway bar mounting kit instead of muffler clamps?
Thanks to zip ties, the brake lines don't seem to be a problem, but I'm still worried about the TA mounting situation. Is that situation overblown or a valid reason for being hesitant about the Moser 12-bolt?
Thanks again.
Thanks again.
Thanks again.
Thanks again.
We install a lot of the BMR trac paks and the Spohn 405 torque arms on Moser 12 bolts. We use loc tite and do not have a problem with the bolts. Bob
