9" With True Trac Or Moser 12-Bolt With True Trac?
Originally Posted by NumberOneSled
I was at the PRI show in Orlando this weekend and when I talked to one of the guys at the Moser booth he told me you couldn't put the True-trac in a 9". He seemed like a pretty knowledgeable guy, is this true?
Originally Posted by Predator
BADSS, I did say the true trac was a "clutchless limited slip" as in gear driven, but this is not important. The other stuff you said was more important, and I appreciate the help!
Thanks Jim, I took notes, but I still want want 4.10s in place of the 3.73s. I have an M6.
I appreciate the great help. I think I'm all set. Thanks fellas!
You sure did! LOL! I missed that post, I apologize. However, the True Trac is not a "soft locker"- which is definitely not the same thing as a posi/limited slip differential. Posi and limited slip are two terms that mean the same thing.
I see a lot of confusion about differentials- and when you said you did not want a posi, I assumed you were thinking the true trac was a locker.
What did you end up deciding to do, Predator?
To everyone else- I know that a 9 inch is heavier, sucks up more HP, has a less than ideal pinion angle, and requires "clearancing" to install in an F-body. But they are widely considered bulletproof- and if you do a search, there are a lot of unhappy 12 bolt owners out there- some who end up buying a 9 inch down the road, and even some who go back to the stock 10 bolt rear (Gomer did, for one).
Besides the reasons I listed, what would be the other downsides to a Ford 9 inch- say with a posi- for street driving?
BADSS, I stand corrected on the "soft locker" comment then. I thought a soft locker was a gear-driven limited slip. In fact, now I don't know what a soft locker is. I do know what a locker is.
Well, I'm going with Jim's recommendation (on the previous page) with the exception of 4.10s instead of 3.73s. I'm pretty sure a Billingsley Strange 12-bolt, completely assembled.
I appreciated your input. Thanks!
Good luck with your 12 bolt. Billingsley is good people- they will help you out if you have any problems with it.
I think a soft locker is the same as a regular locking differential except for the fact that it should lock and unlock more smoothly and make less noise.
Originally Posted by lsevenl
I decided to go with the Billingsley 9''. Ordered it a few weeks ago. I am looking to do it right the first time.
Im sick of the 4l60e's. Im on my third one in less than two years. Fixing the problem with th400 w/transbrake,3500-4000 stall, trans cooler w/elec fan
Also thanks for the explanation of a soft locker, and I see that it's an entirely different animal than the True Trac, it's a type of locker.
Originally Posted by Jimmyz
Is the True-Trac more $$$? The Eaton is more than enough if it is. BTW, thats the setup I have, Eaton posi 33 spline 800 lb springs.
Jim
Jim
