problems getting into reverse??
Old Mar 4, 2002 | 11:46 PM
cheechz's Avatar
Default problems getting into reverse??
anyone have problems with the solenoid that prevents you from getting into reverse when driving? well, mine is sticking even when i'm completely stopped. i need to use two hands to force it into reverse.. or sometimes if i wiggle it enough the solenoid will pop back..
is it easily accessible to replace or lubricate this thing??
or should i just grow some more muscles and keep jamming it? <img src="gr_sad.gif" border="0">
Old Mar 5, 2002 | 12:52 AM
LS1MONSTER's Avatar
Default Re: problems getting into reverse??
Hmmm you might want to have that checked out. But have you tried going into first then go into reverse. That always works for me when I can't get into reverse. <img src="gr_grin.gif" border="0">
Old Mar 5, 2002 | 10:43 AM
BLMONGOOSE's Avatar
Iam having the same problem GM told me to change out my transmision fluid. We will see if that was the culprit when i get my car back from them... Will let you know.
Old Mar 5, 2002 | 01:04 PM
cheechz's Avatar
yeah, i've tried the 1st gear, then reverse thing. that used to work on my old car too.
i cant see transmission fluid needing replacement after less than 5k miles...
Old Mar 5, 2002 | 01:08 PM
CamM's Avatar
I had problems getting my in reverse also and then it would pop out of gear at least 3 times getting out of the driveway. <img src="gr_sad.gif" border="0">
As a last resort I took it to the dealer and they replaced the reverse synchro. No problems whatsoever now. <img src="gr_images/icons/cool.gif" border="0">
