Anybody buy the JEGS driveshaft Safety Loop???
its listed for 34.99 in their catalog. Anybody got one that also has FLP's on there car with a stock driveshaft. How does it work. Is it a bolt in or weld in?
TIA!
TIA!
I've got it. Fit fine with my Grots & 3" Y-pipe. I did dimple the Y-pipe slightly, but it looks like I didn't need to do very much dimpling at all. Not enough to hurt flow in the least. My Y-pipe is an ugly kludge, though, and not to be taken seriously. <img src="gr_images/icons/wink.gif" border="0">
I cut the outer 2 holes off on the Jegs loop, but really you only need to do that on the driver's side. It's a bolt in, and fits great. Why anyone would spend $100 on a DS loop is beyond me. Would I install it again? Heck yes! <img src="gr_stretch.gif" border="0">
It tucks up there VERY nicely. I'm running it with a Denny's Nitrous Ready driveshaft, but the stock shaft would work fine too. Had to remove the seats to lift the carpet to put the bolts in, but install was no biggie.
-Andrew
[ March 07, 2002: Message edited by: Camaroholic ]</p>
-Andrew
Texas Director
I've also got the Jegs loop on my '01 Camaro. I have FLP's. It fits really nice. Close, but nice. No concerns about ground clearance like the BMR piece, and it is much more affordable. You need to trim off both ends of the loop where it bolts to the body. I just centered a line between the bolt holes and cut it off with a portaband. You do need to remove the seats to put the bolts in from inside the car. There is no need to remove the carpet. Just cut a slit in the carpet large enough to get a wrench on the bolt head to hold a back up when tightening the loop bolts. Get the Jegs loop, you won't regret it. <img src="gr_grin.gif" border="0">
[ March 07, 2002: Message edited by: mmiller ]</p>
Location: Richmond, VA Where fast cars, well......are hard to come by.
Looks like you have to put some holes in the floor for it to work. Where do they come out inside the car?
4 holes, 2 on each side
they are under the seats.
Tony, i'm gonna start charging you royalties on that pic <img src="gr_images/icons/wink.gif" border="0">
http://harlan.sketchy.net/hawk/mods/loop.html
i currently dont have any back seats in the car right now. does that mean with the jegs safety loop that im gonna be able to see four bolts stickin up in the back seat of the car?
i just dont know if i like the idea of having to cut the carpet..hmmm....
The loop is nowhere near the rear seats. It's just behind the tailshaft of the trans, which is about in the middle of the front seats. You cannot see the bolts once installed. I already had my center console out, pulled my front seats, and it was not difficult at all, and completely unnoticeable.
-Andrew
-Andrew
