My pinion nut came loose
What could cause that? Onthe last week I had put on the car a 12 bolt, UMI t/a, lca's, panhard and a Spohn sway bar. I have not set the pinion angle yet.
Ok so I have an 05 durango and the pinion nut came off and drive shaft fell off. No whining, no slipping, nothing to indicate that anything was wrong. The only nose it made was the whining when decelerating and it only did it one day and then it came off. Does this mean everything is broken or just reattached? Someone please help because the shops around here only want to tall about changing the whole rear end.
9 year thread bump ![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
Honestly bud its hard to say what happened in there. Main thing is (its flanged on the front right?) Did the yoke start working itself off? If the gears check out (visual inspection with the cover off) and there are no chipped teeth you could try to reset the pinion drag and pray for the best. Most shops dont wanna do this due to liability though I'm sure.
