sometimes 2nd bogs?
Old Mar 30, 2002 | 08:51 PM
DriveATransAm's Avatar
Default sometimes 2nd bogs?
i have been running ET streets on the street a couple times now. Sometimes when i punch it about 30ish it hits first and then on the shift it almost feels as though the converter locks up 2nd <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> . it bogs pretty bad- but the rpms are high above 4K- might have been ~5K
do you think its because the Et streets are a little taller than stock (26x10.5s-16), or that it just hooks on the shift and doesnt know what to do? im puzzled, as it doesnt seem to do it all the time, just ocasionally- usually when im racing someone <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" /> . never had that problem with the 315 nittos <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" /> stall is a vig3200. any ideas would be great <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Mar 31, 2002 | 10:18 AM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Default Re: sometimes 2nd bogs?
Could be torque management rearing it's ugly head?
Old Mar 31, 2002 | 10:30 AM
Reboot's Avatar
By any chance is your car an 01 or 02 with a TransGo shift kit? The reason I ask is that combination seems to have really bad TM issues.
Old Mar 31, 2002 | 07:01 PM
Reboot's Avatar
It's TM, I had the same problem only with the 2-3 shift after having TM removed. There's more to TM with the 01's and your programmer probably missed something (mine did the first time).
Tell me if this sounds familiar, wide open throttle burst the car shifts normally then the rpm's fall to 4500rpm and won't rev and higher unless you pedal it or let of.
That's what mine did and TM was the culprit.
AutoTap a pass and I bet both fuel and timing are being pulled.
<small>[ March 31, 2002, 07:02 PM: Message edited by: Reboot ]</small>
Old Mar 31, 2002 | 08:10 PM
really? Im sending the PCM back tomorrow to get the timing fixed in the first place. its about 23 degrees. i wonder if the low timing would have anything to do with it. its kind of wierd because it only does it sometimes.
ohhhhhhhhhh, which reminds me to remove HPP3- bumped the shift pressure up. good thing i remember. i forgot the first time <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Mar 31, 2002 | 08:12 PM
ive done some highway a-taps where it went from 2-3 and it seemed fine <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
but ive only put maybe 500 miles on the new tuning cause its so crappy out. timing seemed to be about 23 the max at WOT.
*who did your tuning reboot?
<small>[ March 31, 2002, 08:36 PM: Message edited by: DriveATransAm ]</small>
Old Mar 31, 2002 | 09:06 PM
Reboot's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by DriveATransAm:
<strong>really? Im sending the PCM back tomorrow to get the timing fixed in the first place. its about 23 degrees. i wonder if the low timing would have anything to do with it. its kind of wierd because it only does it sometimes.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Mine only did it during cool weather when the car was making more power and only once when I had the extra weight of a passenger. I had John at Speartech do my pcm (great guy to deal with). I think that the 01's TM system is more complex than previous years and requires addition parameters to be changed vs. the 2000 and earlier f-body's.
BTW- I only have between 23-25 max timing, but I never asked for that to be changed because the car currently is making good power 362RWHP 373RWTQ and I don't want to play trial and error with a mail order pcm. I'll wait for LS1 Edit and tune on a dyno.
Good Luck
Old Mar 31, 2002 | 09:34 PM
23-25? do you think you will see more out of the car if you get the timing in a more acceptable range?
right now i dont think ive even seen 25 yet. i used to have 29/30 before tuning. it was near perfect.
Old Mar 31, 2002 | 10:00 PM
Reboot's Avatar
I have never gotten more than 25 degrees on my 01. I think they reduced the timing from the factory.
Here a good link to TM that another member just recently posted.
https://ls1tech.com/ubb/cgi-bin/ulti...;f=23;t=000525
<small>[ March 31, 2002, 10:01 PM: Message edited by: Reboot ]</small>
Old Mar 31, 2002 | 10:11 PM
really? thats odd.
i was the third person to reply to that post <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Apr 1, 2002 | 12:34 AM
it is an 01- no TM as it has been programmed out of there.
the bog is consistant too- its not on the shift alone. it seems to bog till i let off the gas. i havent shifted into 3rd with it like that.
no shift kit either.
im hoping its just the tire height and not the tranny breaking. 5K miles on the tranny. with a new pump about 3K ago (long story <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> )
Old Apr 1, 2002 | 12:35 AM
it feels almost exactly like when you lock up the converter as soon as you shift into 3rd and it bogs down the motor and feels like you arent moving- even though the rpms are way high.
im not sure why the converter would be locking up into 2nd though <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Apr 1, 2002 | 09:57 AM
J&JsTA's Avatar
I have a 2002 WS6 TA/A4 and did a half dozen runs a couple of weeks ago and noticed the dreaded 2nd BOG as well. First run, lots of tire spin in 1st then second and bog,picked up later in the gear. Second run same as first but feathered petal once it bogged in second and got like a gear kick down??? and it picked up(couldn't be jumpin from first to third with all the tire spin???)Third run I squeezed the pedal from the start with less tire spin and the bog wasn't there. Totally confused, is it TC,TM what the hell??? One thing is for sure I not thrilled <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
Old Apr 1, 2002 | 10:35 AM
Nick's WS6's Avatar
I get the same thing with a stock 01. I'm going to the dealer to see if they can find anything.
Old Apr 1, 2002 | 11:43 AM
J&J, do you have !TM?
shifting into 3rd- never thought of that one. i should have a-tapped it. thats a possiblity too.
Old Apr 1, 2002 | 11:55 AM
J&JsTA's Avatar
I still have TM with only 1200 km on the car. The only reason I say that it may have jumped to third is the tires were still spinning when the 1-2 change happened and when I pumped the petal when it went flat I got a definate passing gear type hit( and it didn't jump back to first... revs weren't that high)
No matter what the situation IT MUST GO!!!!!
<small>[ April 01, 2002, 11:58 AM: Message edited by: J&JsTA ]</small>
Old Apr 1, 2002 | 03:05 PM
Nick's WS6's Avatar
I just talked to my local dealer and they never heared of anyone having this problem so for now well have to figure it out on our own.
Old Dec 13, 2005 | 03:12 PM
TopFlite's Avatar
I have been having this exact same problem every so often too. Its only on the 2 to 3 shift on my A4, mainly on the freeway. I thought at first the TC was wacking out closing the throttle blade partially, but it sounds more like TM like you all are talking about. Its a stock computer tune as well.
