10 bolt rebuild - carrier removal?
How do I get the carrier out of my rear diff? I've got the bearing caps off, pinion nut and yoke off, everything is out.
It's suppose to "fall out", but that's a pipe dream. Is there any tricks to this at all? I don't want to hammer on the pinion splines, as that'll just be hitting the gears against each other... any suggestions?
Thanks!
Thanks!
I've tried running a coat hanger through the cross shaft hole, then tying it up above, and using a 4' breaker bar, with the tip on a block of wood to try and lever it out.... no dice. I can lift the entire assembly off the sawhorses by the carrier, and it doesn't budge.
Then I straddled the axle tube to hold it down, and reefed on it, and broke the coat hanger....
do these just fall out for everyone else???
yea, axles out, caps were off, but I put them on with the bolts in 4 threads or so, so the carrier wouldn't fly out and hit me in the head or something.
It is kinda cold in the garage, I might try leaving a heater right below it, and heat it up good, then a heat gun as well....
They don't "just fall out". You do have to pry them out. If it just falls out, your backlash would be wrong and you probably didn't have enough carrier bearing shims.
What we do is get a short crow bar with a flat end. Turn the carrier so the openings face the top and the bottom of the rear end housing. Carefully put the crow bar inside the carrier casing, but NOT on the spider gears or anything else. It will pivot on the rear end housing. One person holds on to the carrier and the other hits the end of the short crow bar with a 2 lb hammer. Sometimes, it takes a couple of pretty firm blows. The person who holds the crow bar and hits it, has the hard job. It will hurt your hands if you don't wear gloves. Be sure to hold on to the carrier. It can come out quickly and hit the floor.
Good luck and buy a 12 bolt or 9" next time.
