Moser 9 inch
The third member is fully assembled, but comes in a plastic case. All you have to do is bolt it into the housing.
You pull out your old axles from your 10 bolt, and use the brake backing plates on the new axles.
You install the new supplied axle bearings and slide the axles in the housing, instructions are supplied from Moser for the above procedures. Bob
We have not had any problems with 5000 rpm clutch drops with nine inch mosers using spools. The Truetrac would probably hang in there as well, provided you're not over 600 rwhp. Bob
