Moser 9 inch
Old Oct 20, 2006 | 09:23 PM
Slow00ls1T/a's Avatar
Default Moser 9 inch
What Is required when you recieve moser 9 in from EPP
Mainly assembly
Old Oct 20, 2006 | 11:51 PM
getusum's Avatar
required?,,,ya lost me on that one/
Old Oct 21, 2006 | 06:31 AM
EPP's Avatar
EPP
The third member is fully assembled, but comes in a plastic case. All you have to do is bolt it into the housing.
You pull out your old axles from your 10 bolt, and use the brake backing plates on the new axles.
You install the new supplied axle bearings and slide the axles in the housing, instructions are supplied from Moser for the above procedures. Bob
Old Oct 21, 2006 | 08:09 AM
ok thanks that is the info i needed
Old Oct 21, 2006 | 09:58 AM
MeentSS02's Avatar
Kleeborp the Moderator™
...and then you proceed to lower your 60' times a little more than currently listed in your sig pic
Old Oct 21, 2006 | 11:30 AM
ya i managed to get a 1.9 before braking the 10 bolt
Old Oct 22, 2006 | 11:04 AM
EPP's Avatar
EPP
1.5 60 ft times are headed your way, all it takes is money... lol Bob
Old Oct 22, 2006 | 11:45 AM
so a 9 in will hold 5k and 6k clutch dumps
Old Oct 22, 2006 | 12:50 PM
MeentSS02's Avatar
Depends on what you do for a posi...they can still be a weak link, but you'll have better luck with the 9" than any other (except for maybe the S60, but that thing is frickin huge).
Old Oct 22, 2006 | 04:29 PM
EPP's Avatar
EPP
We have not had any problems with 5000 rpm clutch drops with nine inch mosers using spools. The Truetrac would probably hang in there as well, provided you're not over 600 rwhp. Bob
Old Oct 22, 2006 | 05:00 PM
bigdsz's Avatar
The Detroit locker will also take maximum rpm clutch dumps.
Old Oct 22, 2006 | 05:05 PM
well ill be ordering 9 in on monday from you bob
Old Oct 22, 2006 | 06:21 PM
EPP's Avatar
EPP
Thumbs up
Thanks, I appreciate it! Bob
