Broken True Trac
I did cut 4 1.6x's 60ft with the car on 275/40/17 Mt Et street radials.
I will be happy if something beside the posi is broken I do not look forward to going thru the warrenty dance with Eaton/Detroit.
Exploded view,http://www.4crawler.com/4x4/TrueTrac.shtml
Let me know what part you are looking for, sorry I didn't get back with you earlier.
Scott @ DLS
I want to know already ahah
2 small chips on the side gear spacer.
1 small chip on the passanger side gear.
Lots of fine metal grit.
I am going to clean the crap out of it and put it back together just like it is unless an expert tells me not to.
Driver side axle notice the wear pattern.Looks like the axle is going completely thru the side gear by about 1/4 inch.
Oil and crap in the bottom of the 9 inch housing itself.
