Thick Gears, any GOOD news?
I've done some searching on thick gears in the 7.5 10 bolt, and all I hear are bad things. Most of the complaints are about noise. Like anyone that has tried them already, I would like to get away from my 2.73 gears without replacing the differential. However, I don't want to waste the money on thick gears if they're no good.
Anyone with positive experience care to chime in?
I had GM OEM 3.73 gears installed in my 10 bolt and they are dead quiet. I beat on them a with my M/T drag radials and they are still quiet, no clutch drops though. I get just a slight amount of whine in 6th gear on the highway if I listen for it real close with the radio off. Got my GM OEM's off of ebay for $100 used, but normally I think they are pretty expensive new.
Thanks for the responses guys, but I'm looking for some feedback on the aftermarket thick gears that allow running 3.23 and numerically higher on a series 2 differential. The searching I've done is almost 100% negative when it comes to how noisey the gears are, but I'm wondering if there's someone out there using them for high mileage without the noise problems.
