Vibration at 100 mph
Old Jun 6, 2006 | 10:03 PM
RedRyder518's Avatar
Default Vibration at 100 mph
I had my gears swapped the other week and noticed that my car vibrates at about 100 or so. This started right after the gear swap so I am sure that it is because of this. I am about to take it back to the shop, is there anything in particular that may cause this?
Old Jun 7, 2006 | 03:35 AM
AceHaag's Avatar
If you put in lower gears it may be because your driveshaft is spinning faster than before.
Old Jun 7, 2006 | 06:35 AM
I did put in 3.73s, which are up from the 3.23s stock. I wonder though how come it is doing that now? Before hand, I've taken it up to 130ish and it never vibrated at all. I also don't have the stock steel LT1 driveshaft but the aluminum LS1 driveshaft.
Old Jun 7, 2006 | 12:45 PM
96_TA's Avatar
So is there anyway to fix this problem? I am currently having the same problem at around 80+ mph. I think I still have the stock LT1 driveshaft though if that makes a difference.
Mike
Old Jun 7, 2006 | 01:10 PM
Mike
You know, I think I may have read somewhere that if you disconnect the U-Joints and rotate the driveshaft 180*, then it puts it back to how it may have been before the gears were installed. I'm going to try that and let you know if it works.
Old Jun 7, 2006 | 01:45 PM
96_TA's Avatar
Cool, good luck and please let me know how it goes.
Mike
Old Jun 7, 2006 | 10:42 PM
CW00BlackTA's Avatar
Mike
In my experience with this issue, the vibration will be better with the Al shaft. Try it and see.
Old Jun 8, 2006 | 03:46 AM
AceHaag's Avatar
Did you change the drive shaft at the same time?
Did you check the u-joints for play?
Did you tires throw the wheel weights?
Lots of possibilities espescialy at those kinds of speeds.
Old Jun 8, 2006 | 10:21 AM
96_TA's Avatar
What is an Al shaft?
Mike
Old Jun 8, 2006 | 10:32 AM
AceHaag's Avatar
aluminum.
Old Jun 8, 2006 | 02:36 PM
96_TA's Avatar
aluminum.
lol ohhh ok
Thank you.
Mike
Old Jun 8, 2006 | 02:39 PM
MrDude_1's Avatar
they already said it, but yea, its probably from the driveshaft spinning faster.
Old Jun 11, 2006 | 09:59 PM
GOOD NEWS: I unbolted the U-Joints at the rear end and rotated the rear 180 degrees and put the driveshaft back in. Absolutely NO more vibration, so go on and try that out.
Old Jun 12, 2006 | 01:43 PM
96_TA's Avatar
Sweeeeet. So you rotated the driveshaft 180 degreees? Counterclockwise or clockwise?
Thanks a lot
Mike
Old Jun 12, 2006 | 01:46 PM
Doesn't really matter. Like I said, I just unblolted the U-Joints from the rear and slid it out, turned the wheels until the yoke (I think that is what it is called?) was turned 180 degrees, and then put the U-Joints back in. Hope it helps you out!
Old Jun 12, 2006 | 04:06 PM
96_TA's Avatar
Sweet, thanks a lot man
Mike
Old Jun 14, 2006 | 11:32 AM
96_TA's Avatar
Just got off the phone with the mechanic...he says the U-joint is all rusted to ****. Hopefully thats what the prob was.
Mike
Old Jun 16, 2006 | 01:00 AM
1sick'98WS6's Avatar
maybe if you drove the speed limit.... haha just kidding i dont know if anyone on this forum always does
Old Jun 16, 2006 | 01:54 PM
96_TA's Avatar
Of course I always drive the speed limit....................................haha
Mike
