3:73s ARE IN!!
Old Jun 26, 2006 | 07:26 PM
gnbooster87's Avatar
Default 3:73s ARE IN!!
i installed my 3:73s gears on thursday and test drove and programed with hyper tech programer, car feels faster but i noticed that it shifts faster at very low speeds, im doing about 30 and its already going to 4th, it shifts faster from 2 to 3rd, some said i should replace my speed sensor since i have new gears, i didnt adjust my shift points cuz im not sure how to. my speedo works fine now, i programed the gears and tire size (26.5). should i really change my sensor the ABS light doenst come on. i went from 2:73 to 3:73
Old Jun 26, 2006 | 07:27 PM
Gun5's Avatar
damn shouldnt be shifting that soon dunno what u did buddy
Old Jun 26, 2006 | 08:36 PM
i wasnt shifting, this regular driving on D
Old Jun 26, 2006 | 09:46 PM
RedRyder518's Avatar
Thats how mine is too, since the RPMs are going to be higher for any given speed, it can upshift at a lower speed and still be in the correct RPM range. I've noticed that my converter locks up at 40 MPH instead of 45 MPH when I had my 3.23s.
Old Jun 26, 2006 | 10:39 PM
infinitebird's Avatar
That's normal.
The shift points in an auto computer are different depending on the gear size. You can convert them and program new shift points that will make it shift at the same place as before if you want.
Old Jun 27, 2006 | 01:20 AM
thats what im trying to do, i have a hyper crap, but i dont know how to adjust my shift points
Old Jun 27, 2006 | 02:32 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
When I went from 2.73 to 3.73 gears, I tried to use my Hypertech to reprogram the trans. The handheld just wasn't able to do it correctly. Later on I had my car professionally tuned, and that's when everything was sorted out correctly. Yes, it's going to shift a lot sooner now, but you'll eventually adjust your driving style to fit it. Just give it some time...
Old Jun 27, 2006 | 04:27 PM
Latin-Man's Avatar
got my 3.73 (M6) in too, its pretty noisy on 5th and 6th. is there a way to quiet them down??
Old Jun 27, 2006 | 10:52 PM
SCREAMIN's Avatar
I went 2.73s to 3.73s on my LT1 and had some gear whine
noticed nearly .3 in the 1/4 and 2 mph, good luck!
