Wheel Studs - which ones?
Old May 20, 2002 | 03:04 PM
TAGOES11S's Avatar
Default Wheel Studs - which ones?
I have 5 bent studs. I have to change out. I plan on getting draglites here shortly so I'm thinking of going with the longer stud for track purposes. But I have Torque Thrusts for street use. Which studs should I get and will they work with the Acorn style lugs for my TT's?
Oh I have a Moser 12 bolt with push in studs.
Dan
Old May 20, 2002 | 03:30 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Wheel Studs - which ones?
I have the 1/2" extended studs in my Moser 12-bolt axles. I run Draglites with a 5/16" spacer and closed long-shank draglite lugs. With the WS6 stock wheels, I also use the 5/16" spacer behind the wheel and I can fit some truck-specific 1/2" acorn, long, closed end, chrome lugs. They look just fine. I have to use the spacer with the stock wheels or the closed lugs will bottom out on those studs. I got them at Pep-Boys
Tony
<small>[ May 20, 2002, 03:34 PM: Message edited by: Nine Ball ]</small>
Old May 20, 2002 | 03:33 PM
Nine Ball's Avatar
LS1Tech Co-Founder
pictures:
<img src="http://users.ev1.net/~ynot_dv8/Chromelugs1.jpg" alt=" - " />
Stock front wheel studs and Gorilla lugs/lock
<img src="http://users.ev1.net/~ynot_dv8/Chromelugs2.jpg" alt=" - " />
1/2" truck-style acorn lugnuts (long body) on rear
Old May 20, 2002 | 08:15 PM
mitchntx's Avatar
http://www.dougrippie.com/drm/wheel_components.htm
studs for the front hubs (or rears)
1/2" longer and OEM size lugs
$13 for 10.
Old May 21, 2002 | 08:27 AM
TAGOES11S's Avatar
Who Manufactures these? ARP? Since I've already bent one side 1.61 60ft, should I go with the racing studs?
Old May 22, 2002 | 10:15 AM
TAGOES11S's Avatar
ttt
Old May 22, 2002 | 01:05 PM
Reckless's Avatar
Super Moderator
Lingenfelter sells longer studs in the stock thread config (12mm x 1.5). Check their web site.
Old May 22, 2002 | 07:32 PM
Bob2of3's Avatar
Wheels up Director
WHEEL STUDS [12MM EXTRA LONG: 3.5"] 22551491
Go to your local dealer with this part number. They should be less than $2, I forget the exact amount put they'll do the trick
Here's a pic of the STOCK wheels and here's a pic of the front Skinnys
LAter <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ May 22, 2002, 07:33 PM: Message edited by: Bob2of3 ]</small>
