T/A rear end girdle.
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I tried a search but got nothing. I bought mine used to begin with. Now the question I have is what are the 2 nuts on the back used for? DO they need to be adjusted? I have a little rear end fluid coming out of them but nothing serious. I checked to see if it was low and it's not.
Originally Posted by gillbot
teflon tape will stop the leaks.
The 2 buts on the back are support for your rear main bearings. Torque them to 5lb-ft.
http://www.taperformance.com/rear.htm
8. Torque the load bolts to 5 ft/lbs. (60 in/lbs.) MAXIMUM, for too much torque could egg-shape the bearings. DO NOT OVER TORQUE LOAD BOLTS.
