Moser 12bolt TA Bolts???
after eating 5 tq arms i finally went with a spohn which is made out of thicker plate and I put a tack on the bottom bolts and loctited the top, almost a year without touching them and no problems but the 12 bolt is coming out and the 10 is going back in...the 12bolt is the worst thing ive ever done nothing an on going headache
Eroc
Eroc
well the first one i had for a year it wasnt too bad but it did leak from day 1 then the axle tube split from the center section while i was driving and it bent an axle so i had to dish out another grand or so for a housing and axle
so now im on my 2nd moser, still pisses gear oil from the pinion and axle seals, ive had it apart 4 or 5 times to replace the seals with no luck, it clunks and bangs under the car and rides like ****, its partly due to the tq arm i have sending alot of noise through the body but so far the spohn is the only one thats held up, might switch back to a trans mounted arm
