Is there a way to reduce gear whine.... cheaply?
I had used 4.10's installed a while back, and two passes down the track... and they whine more than a french guy in a cheese factory.
Any secret potion to cure my problem, or am I gonna have to pay to play? I don't go to the track often anymore.
A temporary and cheap fix is to run a real thick weight gear oil, it will quiet them down some. Or a loud exhaust, it fixes ALOT of problems. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> Good luck, Shawn
<small>[ May 29, 2002, 08:36 PM: Message edited by: SPANKY LS1 ]</small>
http://www.ring-pinion.com/t-diagnosing.html
Some information for you to help you find out what is going on.
You might think I'm kidding but it is said that a little sawdust helps to hush the fuss.
(I haven't tried this and don't know if I would!)
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong>You might think I'm kidding but it is said that a little sawdust helps to hush the fuss.
(I haven't tried this and don't know if I would!)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Saw dust ayy....... interesting. What is the worse it can do ? <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
I have heard of saw dust being used to fix everything from a loud rear end, to transmission slipping to low oil pressure. I heard it was an old trick that used car dealers would use to get rid of cars with problems.. althoguh it reduced the life of the component dramaticaly
(I haven't tried this and don't know if I would!)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">If you pour some sugar in the gas the motor will run real sweet ... NOT!
Colonel, that has to be the most insane tech advice I've ever read ... :shakeshead:
I thought I read some post about redline having a super heavey something like 90/240 weight of gear oil..and thought he said that helped a lot.
I had zero luck quieting my richmond 3.73..tried everything,dynamatted rear of car like three layers in places..tried the heavier amsoil think it was 80/140 or so..no help ,even took off my hotchkis lower control arms and panhard and sold my random tech torque arm thinking that stuff was transmitting the noise.I finally just got rid of the richmonds and went back to the 3.42's until I get a 12 bolt.Maybe try that real heavy redline.
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by mitchntx:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
Colonel, that has to be the most insane tech advice I've ever read ... :shakeshead:</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Don't mistake that for advice! Like I said, I've never tried it and don't know if I would (that really means I wouldn't, btw.)
...But, I do know of those who have.
LS1Tech Co-Founder
I'd look into the Ratech solid collar, I think what is happening is that your backlash is opening up.
I run 85/140 with my 9"/4.10 and it helps a bit.
Colonel, I did not take your comment as "advice" <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I will try out those gear lubes to see if it helps any.
Thanks!!
Thanks!!
</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Sure, give only half the advice. <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
So many questions remain like:
what brand is best (e.g., Is Georgia Pacific worth the extra $$$)?
what wood works best (Is it true that Pine doesn't last and that Apple gives off a funny oder after 5,000 miles)?
should I pressure treat my saw dust or use an additive like Thompson's water seal?
This is a tech forum, buddy; no half-assed answers or I'll give you the boot. <img border="0" alt="[judgement]" title="" src="graemlins/gr_judge.gif" />
<img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
<strong>Oops, just logged on and saw this. Yes, as always, you're right. This is such a new and cutting edge branch of technology that admitidly, I'm knot up on the latest research and I really should have been before I went barking up this tree. Treated or not? Pine or oak? Sorry, I'm treely stumped this time! Wood you forgive me? <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" /> <img border="0" alt="[Firebird]" title="" src="graemlins/formula.gif" />
Geeez we need to label this Colonel guy a TROLL. <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
LS1Tech Co-Founder
HEY COL!
We only use sawdust on cars we trade in!!! ROWR!
I usually use Pine. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Hey guys , let's not go against the grain here. Everyone knows there is always a way to spruce up a diff. Maple I can answer this once and for all. Cedars a way to do this, ash long ash you fine grind the pine to get rid of the whine..
<small>[ June 07, 2002, 06:06 PM: Message edited by: StevieZ ]</small>
