How rough is missing a shift on drivetrain?
Old Jun 5, 2002 | 10:38 AM
ZeeQuick's Avatar
Default How rough is missing a shift on drivetrain?
probably very stupid question but.... <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" /> <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
Old Jun 6, 2002 | 12:52 AM
99MONGOOSE's Avatar
Default Re: How rough is missing a shift on drivetrain?
It all depends on what you mean by "miss" a shift. If you slammed a lower gear then expected: 2nd gear to 1st instead of 3rd or 3rd to 2nd rather then 4th you could bend pushrods, valves or both, you could float a valve into a piston and screw the whole motor. If you simply hit the gate and just rev it probably will just slightly bend a pushrod, depends how high you take the rpms above redline. The rev limiter will only work on accellerating in gear, like if the are at the track (1/4 mile) and riding 3rd you may hit the rev limiter trying to squeeze that last foot or two without shifting to forth. If you hit a wrong lower gear its a manula override and the rev limiter is useless.
Old Jun 6, 2002 | 02:20 PM
ZeeQuick's Avatar
that's what i figured. Thanks
Old Jun 6, 2002 | 07:34 PM
msce2b-dustin's Avatar
The grinding isn't that big of a deal....the motor takes it pretty hard if you throw it iinto the wrong gear.
Back when I raced manuals...before the racing gods showed me the joys of high stall a4's....i pay supper close attention and if fel trouble I would let off and clutch it.
I did the ol 2-1 shift a few times in my m6 Ihad but I could always clutch it nad let off in time to keep from screwin anything up.
one more thing...if you miss or start to miss a gear don't force it....just let it go...there will be more races.
Old Jun 7, 2002 | 12:51 AM
ZeeQuick's Avatar
I missed going from 2nd to 3rd at about 5000rpm.
Old Jun 7, 2002 | 12:58 AM
Colonel's Avatar
I think he means the actual grinding <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> of the transmission when you miss a shift.
No big deal really. Just don't make a habit of it.
And yes, the biggest fuggup you can make is to hit a lower gear than you were in at high rpm.
<small>[ June 06, 2002, 01:00 PM: Message edited by: Colonel ]</small>
Old Jun 10, 2002 | 06:09 PM
ZeeQuick's Avatar
thanks guys
Old Jun 12, 2002 | 04:14 PM
L4m3r's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Colonel:
<strong>I think he means the actual grinding <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" /> of the transmission when you miss a shift.
And yes, the biggest fuggup you can make is to hit a lower gear than you were in at high rpm.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Actually kind sir i did even worse... went from 3rd to 2nd and i was spraying <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> bent one pushrod damn near in half and another almost as bad.... <img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old Jun 12, 2002 | 07:29 PM
Dave's Avatar
I missed a shift at 65 MPH accidentally went into 1st gear <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
8 bent pushrods, 4 bent valves and a partridge in a pear tree <img border="0" title="" alt="[Embarrassed]" src="gr_emb.gif" />
The stock shifter is bloody useless! <img border="0" title="" alt="[Mad]" src="gr_images/icons/mad.gif" />
