ujoint?
Old Aug 5, 2006 | 03:37 PM
Eiyse98ls1's Avatar
Default ujoint?
where can i get replacement spicer ujoints for my lpe 3.5 driveshaft. i went to napa and they only had hd/race napa brand that are greasable. part #'s would be great so i just call to check stock.
thanks
Old Aug 5, 2006 | 04:05 PM
TA TECH's Avatar
Most driveline shop that car the dana joints can get them or might have them! The local shop I use has them both ways solid or greaseable!Ya just need to get the number off them!
Old Aug 5, 2006 | 04:53 PM
Eiyse98ls1's Avatar
basically i just need to find a driveline shop and ask for stock replacement ujoints even though i got a lpe DS.?
Old Aug 5, 2006 | 05:07 PM
TA TECH's Avatar
Yes it does matter if ya had a 4.5 inch shaft they can sell ya one it doesn't matter what size or if its stock most of the time they can get the number off of the old one and get ya one!Why ya replacing anyway?
Old Aug 5, 2006 | 05:24 PM
Eiyse98ls1's Avatar
have a vibration problem after the track. so switch rims and tires back to stock but still there. so i pull the driveshaft and check u-joints. the back u-joint is binding a little and front is fine. hopefully a ujoint fixes it
Old Aug 5, 2006 | 05:26 PM
Eiyse98ls1's Avatar
so i need to tell them its aftermarket? yoke is still stock.
Old Aug 6, 2006 | 12:31 AM
TA TECH's Avatar
All they should need is to look at it and get the number, does it have the dana joints in it already?I usually drop mine off and go back and get it!Heck they can sell me the dana's and install them for me cheap so I just let them do it some times for a few cars other I put them in myself no biggie!
Old Aug 6, 2006 | 03:24 AM
Eiyse98ls1's Avatar
yes it does have dana spicer joints in it now. its a lingenfilter 3.5 ds. im wondering if they used heavy duty joints or not. i found a local parts store that has some dana spicers but not heavy duty. are they that much better or should i just replace with the same ones already in it. i was thinking off calling lpe to find out the part #'s or see if they use a specail joint.well i was going to install at work but if i can get a place to do it for me i might just do that if it doesnt cost alot.
thanks for your help
