12 bolt Diff opinions please.
Today I blew up the diff at an autocross. Sounds like spiders or the carrier it self.
My problem is I have a 3750lb car that is used for Drag Racing, autocrossing and general cruising. I ran 11.03@129mph last year with 1.482 60fts.
But I also love to autocross the car and need a diff in it for the street. Spool is not an option.
My NA power is 500+rwhp and will be adding 150hp wet shot very soon.
Will the Eaton be the best or the TruTrac.
I know the TruTrac will be best for the autocross, but can it withstand a low 1.4 60ft and 700 rear wheel torque?
Thanks in advance for your thoughts.
Rampant
It sounds like you need an B.O.E. unit from Tom's Differential.... with a heat treated set of spinders and the cross shaft, a steel clutch pack and step down to the 400lb preload springs vice the 800 pounders.
A 1.4 60 is going to beat up anything you put in a differential.... no matter if it were a 12bolt, a 9" or a DANA.
PM sent.
Rampant
I have a moser 9" and believe the posi is going to go out soon, any information on whether its possible to beef up the posi in amoser 9" would be GREATLY appreciated....... again spool isn't an option for me either.
I'm guessing the step down to 400lb springs would be for the road racing? 800 still better for drag racing?
For a dedicated 1320 car, I have used the 800lb pack, as long as it wasnt a daily driver. And even then, for a dual purpose car, I would still only recommend a 400lb pack.
Soo....I might just be better off going to a Tru Trac intead of rebuilding the Eaton? I've driven a Locker and a spool and I didn't care for them too much on the street.
Thanks for the info. I'm trying to learn as much as I can.....since my posi is starting to go.
The HD units come with 800's. If you rebuild the Eaton, it can be tuned to reduce heat and wear.... with or without and preload pack.... of which the pack can be can be purchased seperately. I would also change over to the OE solid steel disc clutch pack vice the fiber clutches.
Yup, I agree. Spools are a joke. But lockers are/can be a lot of fun. I love drifting my truck on onramps.....
