Big Thanks to Scott at Driveline-Solutions
Just wanted to give Scott at Driveline-Solutions a big thanks for getting our 12 bolt fixed and back to normal
We had been having some problems with our 12 bolt after a local set the up the new gears..... 4.56's. We went through 2 sets of ring and pinion gears in a total of 150 miles with this local installer(friend). Needless to say we were tired of buying gears and wanted to get it right.
Scott and I talked over the phone for a bit, basically saying that our problems were caused by setup error from our first installer. Scott offered to set it up for us.....if we wanted to make the 380 mile drive......ONE WAY. Well needless to say, my dad and I made the trip to Scotts shop this past sunday morning. We came to the conclusion that it was setup error and then Scott setup our new gears/bearings etc etc.
So far the rearend is absolutely quiet, smooth, no vibrations, and its nice to get the car back on the road.
Again, I would do business with Scott again anytime. Thanks man
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![Hail](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_hail.gif)
![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
Originally Posted by 99WS7
I've been looking at his 9" set up....it will be him or TSP havent decided yet. I've read alot of good reviews of his work though and how quiet they are.
If your still on the fence on who to go to, I would highly recomend going to Scott. If you want the rear to be quiet, he is the man to see.
LS1Tech Sponsor
Thank you Brian for your comments, it's nice to help those that need it the most. The situation you were in unfortunatly is one I hear about to often.
It kinda also proves that a Richmond gear in a factory 12 bolt can be set up to run quietly.
Again, I would do business with Scott again anytime. Thanks man![Chug! Chug! Chug!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_chug.gif)
