Gear Question
Old Aug 22, 2006 | 03:26 PM
Koncrete's Avatar
Default Gear Question
So I was involved in an accident quite a while back... I ended up talking the dealer who replaced the rear end to grab one that was supposedly out of a firehawk (3.42 gears) so I used Efi-Live to edit from 2.73 to 3.42 and all that, but I am 100% sure it's not correct... How do I verify what gear set I have in the rear?
Old Aug 22, 2006 | 03:32 PM
2001NBMZ28's Avatar
Try the calculator at www.f-body.org/gears/
Old Aug 22, 2006 | 09:25 PM
Koncrete's Avatar
im going to have to take the cover off my differential aren't I...
Old Aug 22, 2006 | 11:30 PM
GregP's Avatar
Is your car a manual or auto? I know the gear ratios for the T-56 manual 6-speed. If an auto, tell me the gear ratios for the tranny. Then:
Tell me the gear you are in, the speed you are going, the RPM, and the tire size (such as 275/40R-17) on your car and I'll tell you the differential ratio.
Old Aug 23, 2006 | 11:25 AM
Koncrete's Avatar
yea thats the problem... speedo is off... no real clue what speed im going...
Old Aug 23, 2006 | 11:26 AM
Koncrete's Avatar
guess I will have to have someone pace me
Old Aug 23, 2006 | 11:36 AM
2001NBMZ28's Avatar
They replaced the entire rear? How far is it off? Not much difference between 3.23 or 3.42 depending on the donor car being A4 or M6.
4th, 3.23, 2100 RPM = 71 MPH
4th, 3.42, 2100 RPM = 67 MPH
4th, 2.73, 2100 RPM = 84 MPH
Or get someone with you on the highway and tell them go go 70, match their speed, then look at your RPM's and bounce it off the chart.
Old Sep 12, 2006 | 11:30 AM
Koncrete's Avatar
guess I have 3.23's then... finally found someone to pace me on the highway
Old Sep 12, 2006 | 12:36 PM
MrCadillac's Avatar
easy, put it on jack stands, then rotate the tires 10 times, counting the # of times the drive shaft goes around. then divde that # by 10. bam.
Old Sep 12, 2006 | 02:14 PM
lt1formula2000's Avatar
Or you can just rotate the tire one complete time and count how many revolutions the pinion makes. Now you are going to have to guess a little hear if you see about 2 3/4 turns then 2.73's. about 3 1/2=3.42's
