Fill plug on Moser 12 bolt housing
I believe that one needs a 9/16" alan (hex) wrench to remove the fill plug on the Moser 12 bolt. This is where the factory fill plug would be on a factory rearend. If I am correct on the wrench size where in the hell can you get one at? I have looked everywhere for it. All help will be appreciated.
P.S. I have a hex socket for the fill plug on the rearend cover. This is the plug by the pinion yoke.
Wright Tool Co.
http://www.wrighttool.com/pub/defaul...09027E52D9E%7D
#4218-Socket w/bit
#4218B-replacement bit
OR
find some 9/16 hex steel stock,cut off about a 2" piece,heat it up to glowing red with a propane torch,quench it in used oil to harden it.
#4218-Socket w/bit
OR
Originally Posted by 01ws6450hp
Mine is a 14mm. A 9/16" was too big and a 1/2" was too small. I found mine at Autozone.
10-4 as soon as this work week is over I;m going to call Moser to be sure before I go buying tools. Hopefully I can find a set of larger hex sockets. I hate buying just one.
