HELP!!Loud popping/Clunking Coming from rear of car only when Im going slow?
Tonight as I was getting ready to make a right onto a road from a stop sign I let out on the clutch slowly and this loud popping came from my right rear area, I didn't know what to do so I pulled over looked under the car,everything looked fine.
I proceeded to go further down the road and came up on a stop light and as I was stopped and began to roll forward a bit when the light turn green it popped real loud on the drivers side rear area.
As soon as I got home I put it up on rhino ramps in the rear and with a flash light carefully examined everything all suspension parts/bolts and the rear end and everything looked fine. I cant find anything out of the ordianry. How would I know if the lower control arm bushings were bad? Also it doesnt do it when Im cruisisng down the road only when I am turning real slow. The rear end sounds fine to when Im cruising. Nothing abrnormal there either.
Please help me what should I look for?
Thanks
Thanks
If it was the rear end wouldn't it Pop all the time and not just slowly going around turns?
I dont want to have the drain the flud just yet or take the cover off until I have some for sure answeres...
I really hope its not the rear end, I want to think as that as my last option.
Could it be the cv joint in the driveshaft?
!Dial-up Director
Becasue it only happens when you turn it sounds like the posi. That is when your posi is at work, turning the axles at different speed to compensate for shorter/longer turning radius of the inner/outer wheel.
Justin
Justin
OK pulled the cover off shavings all over the place and two small chunks of something which I presume are spider gears or somehting I fund with a magent tool. I got pictures if I can send them to someone and they can verify for me that these are spider gears. Please help me out. Thanks
Jsears I sent you pics through email. PLease email me back or let me know on here what you think it is. Thanks alot man.
Alex
Alex
!Dial-up Director
WTF, did you strip some teeth? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
The noise is probably those pieces of metal getting caught in the ring and pinion. What do you think Justin?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000 ws6:
<strong>
Could it be the cv joint in the driveshaft?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Doubt that since our cars don't have CV joints. Your refering to the U-joint. That woulnd't be your problem.....I'm guessing pull the cover and check the carrier.
<strong>
