9 inch problem???
Old Sep 18, 2006 | 12:28 PM
2002SilverZ28's Avatar
Default 9 inch problem???
i am currently running a moser 9" with a detroit locker and 35 spline axles. i have been noticing lately that if i am coming to a stop, if i get out of the brake and roll at a very low speed it is like the rear end catches and gives the car a little bit of a jerk forward.
I am almost thinking that this has something to do with the play in the yoke, but it wasnt doing this when the rear was initially installed.
anyone have this same problem or know what it might be? could it be the endplay in the trans causing something like this?
Old Sep 19, 2006 | 12:20 PM
Firechikn's Avatar
I've got the same setup as you. Sounds like the detroit at its finest. It's one noisey, notchy, cluncky diff. But when you stick it, its all worth it. I don't mind all the noise, but I only drive it on the weekend.
Old Sep 21, 2006 | 03:47 PM
CrawlinWS6's Avatar
Import Patrol
From what I have gathered. Is there is alot of play in the detroit lockers. If you take the rear off the ground you can practically turn the drive shaft 1/2 way before in engages the wheels to move. And it is a normal thing for them (so they say).
Old Sep 21, 2006 | 06:30 PM
so from what you guys are saying this isnt really a problem....more of a common thing or an anoyance with the locker?
Old Sep 21, 2006 | 08:25 PM
CrawlinWS6's Avatar
Import Patrol
Thats what I have heard. It's a common experience.
CW00BlackTA's Avatar
Yes. I had one for about 3 months and then pulled it and put in a Truetrac. I couldn't stand all of the clunking and ratcheting around corners. Noisy as hell.
Old Sep 22, 2006 | 12:06 PM
mine has actually been pretty good up to this point. For the first couple of months it was quiet as hell. Now i get a little whine out of it but i really dont have any noise going around corners......it is just when i come to a stop that the car jumps a little.
thanks for your input guys.
Old Sep 22, 2006 | 01:41 PM
That's good that yours is working well. I've heard quite a variety of stories--some good and some not so good. Mine literally sounded like someone was banging on the muffler with a hammer as I went around corners. I got lots of stares--like "when is it going to fall apart?" Maybe I had a bad locker or something. On the bright side, it hooked up and went straight when you hit the gas.
Old Sep 24, 2006 | 01:17 PM
99blancoSS's Avatar
Sounds all normal from what I was told and is why I chose a trutrac. I wanted the locker but was talked out of it
