Noise coming from rear-end during decel
Hey guys im sure this is a repost(search doesnt work) but my rear end whines alot whenever the car is in gear and i let my foot off of the gas. Its the stock gears and everything. I guess its prolly the gears but i really dont know. Any help would be great.
noah
noah
my gears have a whine to them when not accelerating....cause by the momentum turning the diff not the car...or thats what i would believe it to be....its almost as if you turned the motor into a load off of the gears, instead of the other way around....most rearends (from the vehicles i have or had) do this...usually people say use thicker oil to quite it down...im not savvy with diffs tho...im a submarine mechanic not a car mechanic yet
anybody have any idea how much it would cost to get some new bearings put in or if it would even be worth it? Im thinking about possibly just having some 4.10's put in to make it stop so much.
i had my 10 bolt rebuilt fresh with 4.10's and new bearings all over for $600 including gears. you could get yours for around that. add a TA cover too while youre at it.
So basically this will eventually kill my gears? Im trying to decide if it is worth paying to get new gears and bearings or just dealing with it and saving up for the 12bolt/9"
14 Second Truck Club
Were they quite initially? If so you probably just tweaked the crush sleeve. You could pull the yoke and try a solid spacer and see if the noise goes away. It is something cheap to try. It is also possible that you just bent the teeth on the pinion. As odd as that sounds it does happen. Many 10 bolts start out quiet and after a couple of hard launches the pattern changes and you get noise.
It has been like this ever since i got it (40k miles)....im thinkin ill just save up for a new rear end if it isnt something cheap to fix. Thanks for the help guys i really appreciate it.
i think mine is getting that, perfect pattern at 500 miles, 8 burnouts later im getting a little accel whine at 50mph for 5 seconds.
I have had my Moser 12 bolt for 2 years and never beat on it because I have had other issues with the car. Last night I had my first race and by the end it was howling its *** off. It only does it on decel or while coasting, not under load. So I think I will be ok. Anyone ever have a rear go out with this problem?
Originally Posted by 1999Z28
If it's the stock rearend, and no one has ever messed with it, it's probably just a bad pinion bearing.
Dont you find it odd that the noise is only on decel and the more you beat on it the worse it gets? I have a system in my car that is 147.1 DB and I can hear it over that. I think I will just deal with the noise untill next summer. I wanted to go back to 4.11's anyways.
Mine also has a humming sound coming out of the rear end. It actually does it after about 20mph and goes on. Only difference is that it does it while accelerating and not just decel. Any answers?
Sorry, not trying to hijack the thread
