3.73 or 4.10's!
Old Oct 4, 2006 | 09:03 PM
camscam02's Avatar
Default 3.73 or 4.10's!
set up in sig and will be going to a 4400 stall! what gears should i go with!
also with 410's what rpm are you going through the lights at in an auto?
Old Oct 4, 2006 | 09:11 PM
burnzilla's Avatar
I would get 3.73's so 3rd gear stretches out a little more.
Old Oct 4, 2006 | 09:27 PM
SHINER's Avatar
3.73s are the best of both worlds
Old Oct 4, 2006 | 09:38 PM
camscam02's Avatar
i dont care about driveability im looking for 1/4 mile times.
Old Oct 4, 2006 | 09:47 PM
import slayer's Avatar
my mods are similar to yours and you should definitly go with 4.10's. I have 3.73's right now and I will switch to 4.10's and a 12 bolt when I get the money
Old Oct 4, 2006 | 09:56 PM
camscam02's Avatar
why 410's over the 373's?
Old Oct 4, 2006 | 10:30 PM
02 Camaro SS's Avatar
I would definitely get 3.73s if I had an auto. I have 4.11s in my m6 and they would definitely be too steep for an A4 unless you plan to use a 28" tire.
Old Oct 5, 2006 | 01:20 AM
camscam02's Avatar
to the top for the morning peeps! need some advice here please!
Old Oct 5, 2006 | 01:44 AM
old93ta's Avatar
I just went from 2.73's to 4.10's in mine and i like it. it feels tons quicker, but it spins around 2600@70 in fourth. 4.10's should be around 6100@115 and 5900@111mph in third just to give an idea.
I think i'll go with 3.73s if ever need new gears in this 12 bolt. I think they suit a daily driven car better.
Old Oct 5, 2006 | 10:26 AM
camscam02's Avatar
thanks guys any body else?
Old Oct 5, 2006 | 10:09 PM
Jimmard's Avatar
How about 3.90s? They fall right in the middle.
Old Oct 9, 2006 | 02:49 PM
JUICED96Z
Guest
Posts: n/a
So does that mean you will run out of gear if you trap higher then 115????
Or is that just for a stock size tire? aka 26"
I assume a 28 would raise that trap speed?
Old Oct 9, 2006 | 08:41 PM
SPRAYED 01's Avatar
Im in the same boat. Mods in sig. I had 411 with my m6 then converted to a4 a few weeks ago. Went to track on saturday and pulled a 10.8 at 124 but i had to shut down about 130 feet before the end. I was bouncing the rev limiter set at about 6800. This was with a 27 inch tall tire. Im goin to try out a 28inch tall tire as a last ditch effort to not putting in the 373 gear. Ill keep you posted.
Old Oct 10, 2006 | 10:36 AM
bjamick's Avatar
this is what im thinking when you get over 115 your car will shift to OD which will kill your time shifting to another gear, with the 3.73's i believe you should be able to finish in D
Old Oct 11, 2006 | 12:52 AM
JUICED96Z
Guest
Posts: n/a
Drop me a PM when you do, I have a 28 and am looking at a 4.10.
