What Size Slicks On 3.90 Gears
I Was Wondering What Size Slicks Or Drag Radials To Run In The 1/4 Mile On 3.90 10 Bolt Gears I Just Bought From Thunder Racing.which Size Will Perform Better With My Set Up,2000 Z28 M6 Long Tube Headers,cutouts,ls6 Intakes,shaner 3 Throttle Body,pulley,lid Preety Much All Boltons No Cam, Motor Work Etc.
Ok,thats What I Was Kind Ofthinking A 50 Series Drag Radial Is That About 26 Inch Do You Know,in Case I Run A Drag Radial.so A 15 Inch Or 16 Inch Rim Wont Matter Just As Long As Its A 26 Inch Tire.the Gears Are For A 408 Thats Going To Be Going In Soon Well For The Time Being Untill I Blow Up The Rear End,i Dont Really Drive The Car That Much And It Doesnt Allways See The Track I Try To Baby It A Little.
26 for sure
my MT DRs 275/40/17 were perfect. but my Mt et streets 27" are even to tall all motor. the nitrous im hopin will be a diff story. with your mods youll prolly trap in the 113 range which is gonna put you at around 5700 at the traps.
with 3.89 gear-113MPH- 1 OD ratio- tire height 26
i used this formula to pick my 3.89s cause with the nitrous i want to be able to go 133 ( just a number i watn to go no real reason that MPH) and know i wasnt gonna tap my rev limiter set at 6800 with the cam
http://www.fbody.com/calc.htm
stay 26 on motor i drop .3-.4 ths on the 27s
