Strange 12 bolt & Torque Arm Mount
Originally Posted by Mat
Hey guys, to further this thread, any clearance issues with any of the aftermarket Torque Arms while using a Strange? Anything to avoid specifically? I'll be going Strange 12-Bolt myself in a few months as I too won't have the car on the road again until the beginning of May.
In regards to my overall impression of the Strange, it's a stout piece, but my gears are starting to slightly whine after hitting the track and I do not like how it uses an aftermarket ABS sensor that requires adjustment. The Moser uses the OEM sensor that just bolts in. Otherwise it's a true bolt in rear end with no fitment issues.
Originally Posted by MeentSS02
I'd be happy to let you know how it works with my LG torque arm...
Yes I have drop brackets and LCA's on the car already.
Hey there's another question, does your strange accept bolt on Drop brackets the same as the 7.625" 10 does or was that the Moser that accepted those? I'm thinking I remember it being the Strange..
Kick ***. I thought I remembered reading that too and that being the reason I bought the bolt-ins 2 years ago.
Thanks man! I won't be ordering mine until I gots the dinero in hand so I've got time to plan my attack. Gotta factor in the torque arm, new crossmember, possibly the driveshaft etc. etc.
The Strange is supposed to accept the bolt-in relocation brackets. That's certainly my plan
If you got any questions, I'll probably have mine in the car in about a month or so (depending on delivery date).
I will be doing it on my own in my garage. I'll take pics as I make progress on it, from delivery to painting to install. Keep in mind, though, that I ordered this rear end with no ABS or TCS (although my car is a 4-channel). As soon as my SJM ABS Delete and Line Lock gets here, that will be taken care of. So this is going to be a straight up swap (I had new backing plates built in to it as well, so it'll be as drop-in as I can get).
