9 vs dana 60
Old Oct 31, 2006 | 04:05 PM
white mongoose's Avatar
Default 9 vs dana 60
im in tough possition im about to get a rear end but cant really decide on what to go with the ford 9 inch or the new dana 60 what is the big difference on them i herd that the 9 is a little sronger is it true, my car is a camaro ss m6 cam, bolts on ,nitrous im thinking on going to the track probably twice a month and leave hard off the whole every time help me please
Old Oct 31, 2006 | 04:54 PM
rollinna65's Avatar
The 60 is a little bit heavier than a 9" but is definitely stronger. If I ever get a rearend I'm getting a 60.
Old Oct 31, 2006 | 06:53 PM
LorcinLs1's Avatar
i'm in the process of getting a rear too, i'm going to get the dana 60 as well
Old Oct 31, 2006 | 07:23 PM
mzoomora's Avatar
14 Second Truck Club
The Dana 60 is stronger, the both use close to the same amount of power to drive even though the Dana is heavier. 9" is easy to change ratios on and can be built on a bench, have more than one center ready (one track, one street), and there are tons of ratios. Drag only and with a set ratio the 60 is hard to beat, all around the 9" is a great choice.
Old Oct 31, 2006 | 11:43 PM
thanxs mzoomora for the info, are they both easy to install do they just bolt in or am i going to weld or do other things im planing on puting it my self anyone has other opininon about this 2 rear end need a lot off info on then cause plan on getting one by this week thanxs 4 the info
Old Nov 1, 2006 | 05:18 AM
EPP's Avatar
EPP
No welding is required on a Moser 12 bolt or 9 inch. The Moser 9 inch is a very tough rear, and is ready to ship two days after the order is taken. Bob
Old Nov 1, 2006 | 09:26 AM
RoastEmSS's Avatar
my s60 was a direct bolt in, very easy install, had it for about 1k miles and love it.
Old Nov 1, 2006 | 02:35 PM
99ssleeper's Avatar
same here except i've had mine about 200 miles.
Old Nov 1, 2006 | 02:45 PM
black01_WS6's Avatar
Also the 9 inch ships in 2 pieces that cust down on shipping. There is just more options for the 9 inch right now, but that doesn't mean that there won't be for the dana in the future.
I have helped with a couple of dana's now and they are O.K. The 9 inch is just easier to work on. Just my .02
Old Nov 1, 2006 | 03:58 PM
thanxs everyone u guys did help me alot i dint no nothing about the dana 60, with ur help i could choose rear end to get cause i could get the dana way cheaper than the 9 same warranty and everything thanxs
Old Nov 1, 2006 | 08:34 PM
engineermike's Avatar
The D60 is the same basic design as the 12 bolt, and even the 7.5" stocker. It's just a bigger version of the same. I like (and just installed) the Ford 9 because it's a totally different design with alot aspects that are better. I built mine from scratch, learning as I went, and every step of the way I was thinking "huh. . . I wonder why the other guys didn't do that." Build one yourself and you'll understand. . .
Mike
Old Nov 1, 2006 | 10:29 PM
so mike how do u like ur 9 inch sofar do u regret it or ur happy with it
Old Nov 1, 2006 | 10:37 PM
chuckyt1's Avatar
Had a couple of Dana's years back for a big block car. Strong as hell. Have 9 inch now on my F-Body. Don't think you can go wrong either way.
Old Nov 2, 2006 | 06:02 AM
I really like it so far. Once I sorted through the 3 channel ABS (fab'd my own), u-joint issues (1310 x Ford Special), and gear issues (had a faulty set of gears) ahead of time, I assembled it and it bolted right in and worked perfectly from the test drive on. This rear end is so easy to work on, I was kinda' dissappointed that the experience didn't last longer. . .
Mike
Old Nov 2, 2006 | 12:59 PM
N2O-ARMD's Avatar
You guys need to contact Danny Miller at (636-861-3900) he has one of the baddest 9" housing and deals going they. Not that the 60 is'nt a good choise but it is a lot heavier rotating mass will kill ET more than just average weight.
Old Nov 2, 2006 | 04:34 PM
mzoomora's Avatar
Thats true, but a 9" is less efficient so it is almost a wash.
Old Nov 3, 2006 | 11:28 AM
SSCamaro99_3's Avatar
His shop is 5 minutes from my house. I stopped in one day to ask about pricing, and ended up getting a 30 minute shop tour.
Old Nov 3, 2006 | 11:59 AM
hey ss camaro 993 whats the nam eof the shop
Old Nov 3, 2006 | 01:12 PM
Stang's Bane's Avatar
Driveline Solutions
Old Nov 3, 2006 | 03:55 PM
speedfreak440's Avatar
The heavy rotating mass on a D60 is really a non-issue, I am a mopar guy & have alot of exp with the D60 & 8 3/4 mopar rear. Even though the D60 is very heavy and the mopar 8 3/4 is pretty efficient there is absolutely no ET difference between the two rears, on the same car, on the same day. There have been a couple of back to back tests done on this and the D60 actually showed a very slight mph advantage in the 1/4mi. In other words the D60 is extremely efficient, & it happens to be the strongest common rear-end that is still light enough to be practical in a car.
