Changing my Rear fluid, need help
Old Oct 31, 2006 | 10:57 PM
michaelg589's Avatar
Default Changing my Rear fluid, need help
I am wanting to change most of the fluids in my car very shortly. The trans fluid, rear fluid, and a coolant flush. But, the rear fluid change is a little confusing to me. What weight should I use and do I need that limited slip diff. additive? I have a 2000 Trans Am, 6-speed with the stock 3:42 rear. Does this rear need the additive? What is the best fluid to use for maximum performance? Also, what trans fluid should I use for best results.
Old Oct 31, 2006 | 11:08 PM
juicedls1's Avatar
Yes the rear needs the additive for the posi clutches and use 75w-90, on the tranny get a good name brand Dexron 111 Mercon fluid dont put any synthetic in it!
Old Nov 1, 2006 | 09:41 AM
jimmyblue's Avatar
Moderator
Stock Torsen units do not need additive. If you got
an Auburn, then yes, it wants the whale oil. There
is some urban legend that a heavier non-synthetic
diff oil will improve the torque biasing limit of the
Torsen but nothing authoritative I have seen, to
prove it.
Old Nov 1, 2006 | 10:31 AM
TransAminal's Avatar
Nothing wrong with putting synthetic ATF in the T56. I have Mobil 1 ATF in my trans, and its been fine. Better lubrication and longer fluid life never hurt anything.
Old Nov 1, 2006 | 03:24 PM
wow, two completely different opinons on what to do about both the rear and the tranny. one says i dont need additive the other says to use the additive. one says no synthetic, the other says synthetic. WTF
Old Nov 1, 2006 | 03:55 PM
jimmyblue's Avatar
Moderator
You need to know which style of diff chunk you
have. That will clear up the rear end. I have no
opinion on manual transmissions.
Old Nov 1, 2006 | 07:23 PM
camarojunky74's Avatar
the rear end will be pretty easy to know if you got an auburn cause the only way would be thru a stage 3 setup from slp, and easy way to know is what color are your stock shocks... if theyr orange then you got a torsen, if therye blue and yellow you got an auburn. and for the trans a lot of people out here in so cal use the royal purple max gear. horsepower tv put that oil in both trans and diff and picked up i think like 8 rear wheel hp and 12 lb ft of tourque. so i think that oil would be my first choice if i had a 6 speed
Old Nov 1, 2006 | 08:12 PM
carzman5678's Avatar
I say put back in what it came with, a dexron III.
Old Nov 1, 2006 | 11:09 PM
Its just a trans am, not a WS6. I highly doubt its got any kind of SLP option. So I'm pretty convinced its just a normal torsen diff. So does that mean, I dont need the additive? I can just put in some Royal purple oil and be done with it? I've always assumed I would use Royal purple. I'm just wondering what weight to use. 75-90? or should i go lighter/thicker
Old Nov 1, 2006 | 11:10 PM
OH, my shocks are orange
Old Nov 5, 2006 | 09:05 AM
anyone else have anymore input?
